Old 01-22-2007, 11:08 PM
Beef66 Beef66 is offline
New clutch need help...
We just finished installing my new clutch. Just went to start it up for the first time and it runs fine. I tried to put it into gear and it wont go in, im assuming I need to bleed my slave to fix this one...But I started it in gear just to see if the clutch was working and having the clutch pedal the whole way to the floor when I let off the break the car starts to pull out. No gas or letting off the clutch. Any Ideas? I need to get her back on the road asap
Old 01-23-2007, 01:12 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: New clutch need help...
Upon changing the clutch not only do you need to bleed the system but you are going to have to adjust the clutch pedal
Old 01-23-2007, 01:51 AM
Morphius289's Avatar
Morphius289 Morphius289 is offline
Bleed that bitch.
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 01-23-2007, 12:46 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
i assume you already filled the transmission with fluid?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-23-2007, 12:55 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
ahh the simple things that stumble us... haha
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 01-23-2007, 02:57 PM
Its all worked out...Adjusted the pedal and it fine now. Thanks for the help
