Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-22-2007, 06:26 PM
tazd tazd is offline
Cat recomendations
I have a 96 passport and i need to replace the cat on bank 2.
What do you guys and girls recomend as a good replacement for it . As a note this is a CA car so had to be carb legal.
Also which cat is bank 2 ? as the haynes nor the chilton manual tell you which is which.
Many thanks in advance for any and all help.
Old 01-22-2007, 07:09 PM
surferfletch surferfletch is offline
Re: Cat recomendations
Bank 2 is driver's side.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 01-22-2007, 07:13 PM
amigo-2k amigo-2k is offline
Isuzu Guy
http://cgi.ebay.com/ebaymotors/98-02...74590115QQrdZ1
I don't know why a shop couldn't cut the pipes on this one and then weld it in???
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-22-2007, 07:24 PM
Isuzu Guy
http://www.ecatalyticconverter.com/i...96-22-cat.html
-Ryan
Isuzu Moderator
Car Show Tips
Old 01-22-2007, 08:48 PM
trooperbc's Avatar
trooperbc trooperbc is offline
call up your local muffler shops and get a quote. they will probably want to weld it on, (they're cheaper), but then if you want to replace something there you're stuck. i'd ask for the oem type bolt on (it will cost a bit more).
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 01-23-2007, 12:14 AM
AZoner AZoner is offline
You might want to check CA CARB specs. I believe that their specs call for only OEM, or OEM Qualified direct fit units; as per CA EPA reg's... etc... if they check for replacement of the CAT's that is.
Otherwise go with the flow... or least money.
Get into the Zone
'97 Zu 3.2L 4X4 - Stock - BUT IT's MINE!!!!
Old 01-24-2007, 07:47 PM
Thanks for all the help and info. got a new cat on the way so i can enjoy driving the car again soon
