Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-22-2007, 05:06 PM
SySt3mR00t SySt3mR00t is offline
Send a message via AIM to SySt3mR00t
2.0n/t tranny in 1.8l DSM
Hey guys, found a really cheap clean 1.8ldsm with no tranny (manual). I have spare 2.0 n/t manual tranny laying in my garage. Is it possible for me to bolt the 2.0manual n/t tranny to the 1.8???
THANX A TON IN ADVANCE !
96 GST
Old 01-22-2007, 05:34 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: 2.0n/t tranny in 1.8l DSM
I don't think so.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 01-25-2007, 03:09 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
I'm not sure on this issue, now if you had a turbo tranny and a non-turbo car, yeah it would work... (The F5M33 will bolt in place of the F5M22 [don't do it the other way, I could explain the tapered bearings, but I'll keep it short... DON'T)...
I'm not sure a/b the 2.0 to the 1.8...
Does anyone even know the 1.8l transmission code/designation?
^Isn't that motor the 4g37?
Edit:
A quick look on e-bay has led me to form an opinion...
That's the 4G37's transmission (f5m21)...
The bellhousing on that transmission looks a lot more shallow than the bellhousing on the F5M22 or 33...
I think they will bolt onto the 1.8l block, but I do not think that the clutch will go onto the input shaft...
I may be wrong, but that's my $.02
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 01-25-2007, 04:01 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I'm 99.9% sure that even if it did bolt up correctly, it would not be usable.
95 Talon TSI AWD
97 Eclipse GST
Old 01-25-2007, 05:23 PM
Mikelb's Avatar
I'm still unsure on all of this, but this guy claims to have done it...
http://www.dsmtalk.com/forums/archiv...p/t-68496.html
93talon2.0
10-26-2003, 09:51 PM
Does the 1.8 Tranny bolt up to the 4G63 N/T engine if its out of the same year?
-Do any of the Radiator lines need to be moved or changed?
-How much will the car drop in ground clearance from the heavier 4G63?
-Are ALL the engine mounts in the right place for the 2.0?(meaning is it completely plug and play? or will i need to do some fabricating, if so on what mounts?)
The answers are : Yes the tranny bolts up no problem..the only place that you would need a new tranny is a turbo engine..but if your going n/t to n/t then your fine.
No radiator lines need to be moved or anything.
Everything is bolt in and plug in the new harness, no modifications nessissary. good luck
