Old 01-22-2007, 04:40 PM
mj1061 mj1061 is offline
91' wipers
the wipers and windshield washer on my 91 blazer stopped working. checked the fuse that is fine, would the motor or switch cause both wipers and the washer go out at the same time?
Old 01-22-2007, 07:49 PM
old_master's Avatar
Advisor/Moderator
Re: 91' wipers
On a '91 Blazer, the windshield wiper switch could cause the wipers and washer to be inoperative. Both circuits get power from the same fuse. It would be unlikely that the motor would cause the washers and wipers to fail at the same time. Most auto parts stores have the replacement switch. It pulls out of the column and the harness is routed under the column cover. The new switch/turn signal lever just pushes back in.
Old 01-23-2007, 03:00 PM
Re: 91' wipers
if it is the switch is there a way to check it or anything else it could be? i know very little about how how to check electrical circuits . so the simpler the better would be good. thanks.
Old 01-25-2007, 03:34 PM
Re: 91' wipers
it says in the manual i have for this vehicle that it has a fuse and a breaker for the wipers, would the breaker be in the fuse block ?
Old 01-25-2007, 04:21 PM
old_master's Avatar
Advisor/Moderator
Re: 91' wipers
Fuses and circuit breakers are all in the fuse panel. Check your owners manual for other accessories that are on the same circuit. If they also are inoperative, the chances are good that the fuse or breaker is faulty.
Old 01-26-2007, 02:46 AM
DelCoch's Avatar
DelCoch DelCoch is offline
Re: 91' wipers
Sounds like the Wiper Motor Pulse Board Module is bad, as it also controls the windshield washers. A whole new wiper motor is less than 50 bucks at AtuoZone.
Old 01-26-2007, 05:22 PM
old_master's Avatar
Advisor/Moderator
Re: 91' wipers
It's a '91... not equipped with a pulse board in the motor. The pulse module is a separate part and the washer circuit does not go through the module.
Old 01-26-2007, 10:20 PM
DelCoch's Avatar
Re: 91' wipers
Ok, I was thinking the pulse board activated the wipers when the washers were activated.
Old 01-30-2007, 03:16 PM
Re: 91' wipers
sorry ive been away and havent gotten back sooner thanks for the previous info. could someone tell me how to check the wiper switch to see if that is the problem and how to replace it if it is? do you have to pull the steering wheel to do it?
