Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-22-2007, 02:48 PM
delucaj delucaj is offline
Question '99 Suburban Washer Fluid Pump Problem
The windshield washer pump on my '99 Suburban is not working. When I turn the control, nothing happens. How do I know if it is a problem in the control or at the pump itself? I haven't checked yet, but I believe the pump is mounted next to the reservoir. Am I correct? I checked the fuse and it is good.
Old 01-22-2007, 04:08 PM
Old Dave Old Dave is offline
Re: '99 Suburban Washer Fluid Pump Problem
You should be able to check to see if the pump motor is getting +12VDC by connecting a voltmeter of test light to the wire going to the motor and hitting the washer button. If you have juice there, the motor is bad. If you don't have it there it's time to trace it backwards. I don't know on a 99, but on 98 full size trucks the pump is mounted on the reservoir.
1970 GMC 2WD shortbed fleetside
1984 Olds Delta 88 (won't die)
1997 GMC Suburban K1500 W/5.7L Vortec
2000 Dodge Ram 1500 4WD Shortbed Ext. cab
1998 Chevy K2500 W/5.7L Vortec
2002 Harley Custom Chopper
Wife is a late 1951
