Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-22-2007, 01:19 PM
jomilig jomilig is offline
94 camry, problem shifting out of park
Recently, my camry has problems shifting out of park. Normally I would press the brake and it would shift. Now i have to push the override switch to get it running, but now my brake lights are not working. I checked the fuses and nothing is blown. Any Suggestions?
Old 01-22-2007, 02:44 PM
csaxon csaxon is offline
Re: 94 camry, problem shifting out of park
Check the brake light switch under the dash. It's either sticking or needs adjustment or it's bad.
It worked fine until I fixed it!
Old 01-23-2007, 12:21 PM
don24mac don24mac is offline
Yep, brake light switch will cause that. As mentioned by csaxon, it's under the dash just above the brake pedal area. Looks like a button switch. As you push the brake pedal, the button type switch makes a connection and lights the brake lights and releases the "Park" mechanism in the tranny.
Old 01-24-2007, 03:10 PM
yea thanx, it was the brake light switch...its a little tough to get to...
Old 01-24-2007, 05:52 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Did you simply adjust it, lubricate it or was it in need of replacement?
Mike
