Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 01-22-2007, 01:00 PM
bigsab bigsab is offline
having problem with my check engine light
i have a 99 mercury cougar ive had for about a year n a half i had a problem with my check engine light like 2 days after i bought the car and got it checked and they said it was my oxygen sensor so i went and got it fix but after i got it fixed the light came on again for like about 1 to 3 hours,then it went back off, so now its happened again a year later and auto zone is telling me that its my catalytic converter because a code po420 keeps popping up and it says something about cylinder 1 isnt performing correctly and something about a OBDII , i just wanted to find out if this is the problem or do i just need a tune up, cause i havnet got a tune up on this car yet ever since i bought it because i just havent had the money for it , i bought some spark plugs the other day for it and i was gonna see if that works, soooo somebody please tell me what should i do , cause im really having a hard time finding a catalytic converter for this car , theres none avalible in the local stores
Old 01-22-2007, 01:42 PM
KimMG KimMG is offline
AF - Advisor
Re: having problem with my check engine light
Are you only getting one code or multiple codes? If multiple codes then post all the codes. Cylinder not performing correctly is vague and can mean a lot of things.
OBDII is the onboard diagnostic computer.
Old 01-22-2007, 06:24 PM
cougar4life cougar4life is offline
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
A number of things can cause this. What exactly is it saying about cylinder 1? If it is a misfire it could actually be causing the p0420 code.
2001 cougar 2.5V6 AUTO Trubendz catback,SVT uim and TB,K&N intake and someother non performance stuff
Old 01-23-2007, 01:42 AM
that first line you put up is what the code is saying , im hoping i just need to change my spark plugs because i havent changed them since i had the car.do you think i nee to change the wires and the distributor cap and rotor too, or should i check the oxygen sensors , i herd there's two o2 sensors in my car , is this true?
Old 01-23-2007, 01:00 PM
AF - Advisor
Doing a tune-up won't hurt. The following is two links you may find helpful.
http://www.autozone.com/servlet/UiBr...3d801bbdbb.jsp
http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html
Old 01-23-2007, 02:10 PM
I would go ahead and do the plugs and wires because like KimMG said it wouldn't hurt. Oh BTW you don't have a distributor and rotor.
I would really recommend checking out http://newcougar.org/forums/index.php
