Electrical Issue
I am having a problem when I first start my car up the volts read usually around 9 sometimes less. So my stereo will start to cut out and if my headlights are on they will start to flicker, but if I rev the car up to about 3500 or so the volts rise to about 14 and it is fine until I turn the car off. I had my alternator and battery both replaced and it still does this. So if anyone knows anything about this problem it would be greatly appreciated if you could help me out on this one. I really don't want to have to take it to Mitsubishi to have them diagnose the problem. Thanks in advance.
Re: Electrical Issue
when replacing your battery and alternator, did you ever have them tested to see if they were bad? autozone and other local chain auto parts stores do these kinds of tests for free. granted, i'm pretty sure you'll have to remove the parts and take it to them. call first, but i don't think they can do an on-vehicle test.
what year model is ur car? how many miles?
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Does it do it when it is cold too or is it only when the car warms up?
Ground wires would be my next guess.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
I also read on 3si a week ago about some other people having this exact same problem but no one knew what was the cause of it.
Check out this thread and also the link I posted in that thread. I'd suggest replacing them, either on by your own design, or the kit mentioned in that thread.
I forgot to mention one thing that I believe is related to this problem. When my car is off but I have the stereo on it will work fine, but if I crank up the volume it will start to cut out like there is a lack of power just like when the car is on except I can't "fix" it sense it can't be reved up when it is off. I'm hoping getting those ground wires will help with all of this. |
