Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 01-21-2007, 11:52 PM
Sonny05 Sonny05 is offline
Question Water Leaking From Under Dashboard !!
Everytime that it rains water leaks down from under the dashboard on the passenger side of my 99 tahoe.
Any ideas on how to stop this ??
Old 01-23-2007, 11:27 PM
amw_yo amw_yo is offline
Re: Water Leaking From Under Dashboard !!
i am having this same problem, it never does it when the ac runs or anything, and only leaks in a heavy rain. don't feel alone and if i find out anything i will be sure to post it.
Old 01-27-2007, 09:28 AM
sprucegoose's Avatar
sprucegoose sprucegoose is offline
Lightbulb Re: Water Leaking From Under Dashboard !!
I had this same thing happening for some time with my GMC S15 truck. I found that there was a slight crack that had opened up in the body sealing caulk that is used to seal the sheetmetal together in the firewall. Every time it rained there was a small pond on the passenger side of the floor!
If you look in the fresh air intake area right directly below the windshield (where the wipers are) you can pull off the screen that covers that area by removing the screws or small clips. Then clean it out very well, this area will sometimes get polluted with all kinds of leaf debris and other crap, and will dam up in there rusting the seams...
Slowly pour water over it while someone else watches for leaking inside. You may need to remove a few more things under the dash to see where it is coming from as well. Once I found the crack I scraped away the old stuff and put new calking in there and it never leaked again. Good luck with your repair!
~Dave~
'08 Chevy HHR SS, Victory Red, 5 spd. 2.0L Turbo, 52K mi.
'98 Buick Riviera, Black, 3.8L Super-Charged, 228K mi.
'98 Chevy Tahoe LT, 5.7 Vortec, Black 241K mi.
'70 Pontiac Firebird Formula 400, 4spd 200k+ mi., in process restoration
'10 Dodge Grand Caravan SE, 11K mi.
Old 01-27-2007, 09:35 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
The most common thing I see is the seal on the windshield creates a leak. Dealerships actually hire a person to find and fix leaks. This is all this person does is look for leaks and repair them. The sad thing is that they usually have more work than what they can get done!!!
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 03-04-2007, 12:14 PM
etylercathey etylercathey is offline
I've had this same problem. My leak was the result of a bad seal on the windshield, specifically on the top side of the glass. The water was leaking down the front 'A' pillar and flooding the front passenger floorboard. Scraping out the old, cracked sealant and replacing it with a windshield sealant from my local auto parts store fixed this.
