Old 01-21-2007, 05:01 PM
bmx419gt bmx419gt is offline
DSM purchase
I was thinking about getting an Eclipse from '94-'99, something about $8g or less....less. But i was wondering which trims are available and which has the biggest or best motor? Perhaps if someone knew a website that offered that info for older cars would be awesome. I don't know anything about Eclipses that is why i need help.
Old 01-21-2007, 05:41 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: DSM purchase
This covers both Eclipses and Talons...
90-94 = 1st generation = 1g
95-99 = 2nd generation = 2g
RS = ESi = 420a motor = lowest model with fwd
GS = 420a motor and i believe they also offered the 4g64 motor with it = 2nd model up with fwd
GS-T = TSi = 4g63t motor = lowest turbo model with fwd
GSX = TSi AWD = 4g63t motor = mightest turbo model with awd
So, if you want mad power then I would go with the GSX or the TSi AWD... If you just want a cheap daily driver then I would go for one of the non-turbo models... Generally the Talons run a lot cheaper than the Eclipses do, but its pretty much the same car with a different front end and rear end. Same concept as Camaros and Firebirds. Same car, slight visual differences.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-21-2007, 06:49 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: DSM purchase
The 4g64 2.4L motor only came in the Spyder GS (convertible). All other RS/GS/ESI models came with the 2.0L 420a chrylser motor. GS-T (Spyder and hardtop), GSX, TSI, & TSI AWD all came with the 4g63 turbocharged motor. The 90-94 came with a 6-bolt 4g63 motor which seems to be stronger than the 95-99 7-bolt 4g63 motor, but anyone that plans on upgrading usually does a swap, putting the stronger 6-bolt motor into the 95-99 model cars.
95 Talon TSI AWD
97 Eclipse GST
Old 01-21-2007, 07:13 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: DSM purchase
Actually Garrett, only the 90-most 92's got 6 bolts. Some late 92's and all 93-94's got 7 bolts.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-21-2007, 10:21 PM
Re: DSM purchase
This is true... I suppose I should have gone into more detail about the 6 bolts and 7 bolts...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-22-2007, 10:42 AM
Re: DSM purchase
God damnit, I know better than that too. I got too jumbled up trying to get everything else straightened out, but you are correct Dustin.
95 Talon TSI AWD
97 Eclipse GST
Old 01-22-2007, 01:36 PM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
Re: DSM purchase
some info for you:
http://www.dsmtuners.com/sub.php?page=modelguide
http://www.dsmtuners.com/sub.php?page=1g2gcomparison
http://www.dsmtuners.com/forums/showthread.php?t=55410
www.vfaq.com
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 01-22-2007, 02:19 PM
Re: DSM purchase
Thanks a lot. I think i'll probably get a 95'-99' GS-T or GSX if i can find one for a decent price. For the 7 bolt motors though, what is crankwalk, and is it a really bad thing or just a minor problem. I'm not looking to mod too much just basic for now like intake and exhaust.
Old 01-22-2007, 09:39 PM
Re: DSM purchase
It's a very bad thing. It requires new internals. I'll let someone else explain it because I might not to the best of jobs. Maybe Blackcrow(from experience), thor, or gthompson can help you. It's all over the internet though. Its on this site and dsmtuners.com if you want search for a minute. It has plenty of write ups!
Old 01-22-2007, 09:59 PM
Re: DSM purchase
There's a couple theories about why it happens, but basically a quick rundown is this: The main crank shaft bearing wears out and the crank starts to wobble back and forth. Eventually it knocks out the crank sensor and the whole car shuts off and will not restart until you fix the sensor. The thing is though, by the time it hits the sensor, the crank, bearings, and sometimes the block is fucked and it's time for a new motor. There are a bunch of articles on it out there, and a couple of pretty strong theories, so if you want a complete rundown, google "Eclipse crankwalk" "4g63 crankwalk" or something to that effect and you'll get a bunch of info.
95 Talon TSI AWD
97 Eclipse GST
Old 01-22-2007, 10:03 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: DSM purchase
Even simpiler... parts on or around the crank wear down, causing it to wobble and break stuff. Important, expensive, needed stuff, like internals.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-22-2007, 10:10 PM
Re: DSM purchase
Yes, but it's the main thrust bearing that wears out first and causes it to wobble side too side.
95 Talon TSI AWD
97 Eclipse GST
Old 01-25-2007, 05:45 PM
Re: DSM purchase
whoa. i think ill just get something else, after reading some other forums about crankwalk. its not worth risking i dont think, but thanks anyway for the help and good luck with your dsm's lol.
Old 01-25-2007, 07:56 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: DSM purchase
Damn he got scared away fast...
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-26-2007, 12:39 AM
Re: DSM purchase
Thats funny. 1g ftw I guess.
cough*vagina ftw*cough
