Go Back   Automotive Forums Car Chat > Nissan > Frontier | Navara
Old 09-26-2002, 05:10 PM
tanggoman tanggoman is offline
Send a message via Yahoo to tanggoman
Fuel Filter
I thinking of replacing my fuel filter. Is there anything I need to watch out for besides gas coming out of the hoses??? Do I need to turn off anything???
Thanks
Old 10-02-2002, 03:09 PM
BestNissanParts BestNissanParts is offline
The answer to both questions is no. In order to minimize fuel leakage, you may pinch off one of the fuel hose with a pair of vise grips. If you would like, you could pull the fuel pump fuse and let the truck run until it dies; then install filter and reinstall fuse. This would allow you almost no fuel loss, but is not necessary. Otherwise, there is nothing to turn off. If you have any questions feel free to e-mail me at Ray Brandt Answer Guys
Best of Luck,
The Ray Brandt Nissan Answer Guys
Answering you technical Nissan questions using over 50 years combined experience.
Ray Brandt Nissan
Top quality OEM Nissan parts:
Best Nissan Parts
Old 11-26-2002, 03:06 PM
zipster223 zipster223 is offline
fuel filter
NEVER EVER pinch a fuel line with anything.
The proper way to change a fuel filter is to take out the pump fuse. Run enginge until it stalls then remove the gas cap. Then you must remove the negative terminal.
Old 02-11-2003, 07:16 AM
bbetten769 bbetten769 is offline
Where is the fuel Filter located on a 2000 Fronter 3.3 v-6 4wd.
Thanks
