Old 01-21-2007, 11:45 AM
dport dport is offline
To many miles?
Ok, i'm looking at getting a 1992 Dodge Stealth RT/TT AWD, is ~140,000 miles to much for this car? Or will I be looking at doing a lot of maintenence (sp?) to the car to keep it running. I don't want any surprises with this car when it comes time to drive it. I'd just like to know if thats to many miles for the car, and if I should just look elsewhere.
Old 01-21-2007, 12:42 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: To many miles?
Regardless of miles these cars rquire a LOT of maintenance. With a TT that has 140,000 miles you should definately have a few thousand se aside for maintenance and repairs. It also depends how it was driven by it's last owner. Whenever I buy a used car I always expect to make a few repairs after buying it and then put that into my budget.
Old 01-21-2007, 12:48 PM
Re: To many miles?
Would the car still be reliable enough to be a DD?
Old 01-21-2007, 02:19 PM
Hotshot8792 Hotshot8792 is offline
Re: To many miles?
once again, depends how the car has been driven in the past and what kind of condition it is. One of my best friends has a 93 RT/TT with over 180K, its his daily driver, and its as reliable as any other car. He's getting ready to to do his 3rd 60K tuneup since he's had it.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 01-21-2007, 02:34 PM
Re: To many miles?
I was told that he has all the records of the work thats been done to it. so i'm going to ask to see those, and take it to my mechanic as well before I buy it.
Old 01-21-2007, 03:01 PM
VR43000GT's Avatar
Re: To many miles?
Also have him look at the transfer case and see if it is leaking. That is a common problem for stock t-cases and if it is you should be able to knock the price down a bit.
Old 01-21-2007, 03:22 PM
Re: To many miles?
Will do, thanks a bunch, are there any other things I should keep an eye out for?
Old 01-21-2007, 03:27 PM
Re: To many miles?
a leaking transfer case is covered by a mitsubishi recall. If it is leaking, take it to the dealership, they have to fix it for free.
Old 01-21-2007, 03:31 PM
VR43000GT's Avatar
Re: To many miles?
^^ First talk him down because it is leaking (if in fact it is) and then get it fixed for free.
Old 01-21-2007, 03:55 PM
Re: To many miles?
Will deff. get it looked at, its to snowy here to be crawling under the car, so when I take it to a shop i'm going to look at that and at the oil cooler as well.
Old 01-21-2007, 09:43 PM
AutostradaVR4 AutostradaVR4 is offline
Re: To many miles?
when you look at the records, check to see if/when the turbos were serviced and when the last 60k tune wad done. 60k in case your not familiar, is timing belt, water pump, oil pump should have been done around 120k, and some other misk belts and tensioners. More info about it in the FAQs.
also, the syncros can be issues on these cars. Make sure it shifts smoothly.
like i said man, theres a whole section in the faq about what commonly goes wrong with these cars. check it out.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 01-22-2007, 04:15 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: To many miles?
i think your best bet is to check out the faq like they said
syncro's, turbo's, suspension, ya might have tons of oil leaking into your combustion chamber...like mentioned there's many things that can go wrong if not properly taken care of
just check out the faq
