Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 01-21-2007, 10:14 AM
barbied barbied is offline
windshield wiper spray
I cant tell where the pump is on a 93 626 - no spray and cant hear pump.
could this be on a fuse somewhere?
wipers work, but no spray.
Thanks for any help..
Old 01-24-2007, 09:29 AM
ude_loose's Avatar
ude_loose ude_loose is offline
Send a message via Yahoo to ude_loose
Smile Re: windshield wiper spray
hey. i had the same problem with my 91 626 and checked fuses replaced a couple and nuthing...so i had to replace the pump which was located under de washer fluid reservoir...just take out the winshield washer reservoir it should be stuck somewere in the outside...also find the cable plug that come out of the pump and clean it first...then see if it works if it does u fixed ure problem..if not replace the pump and u'll b good to go...
