Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-21-2007, 07:39 AM
jupilerman jupilerman is offline
pre-rad size for chargecooler?
Hi all,
I am planning to boost my little 1.8litre engine with a mere 6-7 psi.
air/air didnīt work out as it is mid engined. Bought a small charge cooler.
However, I couldnīt find information about sizing of a pre rad for cooling the charge water. Iīv read about people using oil coolers and even airconditioning condensors. These seem to be more effective doing their job than regular water coolers. I am not into all the different fin types that exists in these coolers, so was hoping to get some info on here.
cheers,
david
Old 01-21-2007, 12:43 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: pre-rad size for chargecooler?
something like an ~8x6" Setrab oil cooler mounted where it can get ambient air (possibly under the car, maybe with a scoop to catch more air) would be good to cool the water, of course the bigger the cooler, or the more of them, the more efficient the charge cooler will be.
don't forget you'll need a water reservoir in the system, so water comes out of the chargecooler, into the pump and then into the reservoir. most of the cooling for the water is done in the delay between it leaving the chargecooler and going through the rest of the system, so by the time it's out of the reservoir and back to the cooler it's at a reasonable temperature again.
Seatbelts Saved My Life
Old 01-21-2007, 12:54 PM
UncleBob UncleBob is offline
AF -Advisor
its a question of how much heat you need to disapate, and how quickly you need to do it. The larger the tank is, the less you can get away with, as far as cooling capacity.
At 6-7 psi, you won't need much, since that produces very little heat. I personally would use something larger than an oil cooler. They are too restrictive, same goes for condensors. Heater cores work very well, if you want something on the smaller end. Even better, a motorcycle radiator
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 01-21-2007, 01:07 PM
Thanks for the swift replies guys. Appreciate it.
Since the charge cooler will be on the highest point in the water circuit, I also have a filler neck attached to it.
Basically thereīs two kinds of pumps. The impeller one and the magnetic.
The magnetic loses quite some flow when headloss gets higher, but then it doesnīt leak. The impeller gives higher flow at higher headloss, but then breaks down easier. Since this is sortoff a weekend/holliday car, Iīll go for the impeller ones. Easily found cheap on fleabay. Mostly from standheating systems in Merc end BMW (cold countries like germany, austria or Northern US). They flow 13-19 l/min (3.43 - 5 gal/min).
So the coolant reservoir should be after the rad? right? this is the buffer of cooled water. It could turn out to be a heat soak though? But then, at 3l capacity, it wouldnīt soak that much in a minute ;-)
cheers
Old 01-21-2007, 07:18 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
You are looking for a radiator to dump the heat from the CC water back into the atmosphere?
My Lotus Esprit has a stock (sorta) Charge Cooler system and has a separate 8" by 33" radiator for it at the very front of the car. It is important that this radiator gets first crack at the cool air and is as big as possible. If you are going to be driving twisty roads in this car, avoid reservoir tanks (despite what Corkey Bell says) and go with big radiators. On my car, there is a small expansion chamber--maybe 10 ounces-- that receives the bleed water at the top of the CC. No reservoir tank is used because the tubing going to the front of the car is so long that it holds quite a bit of water anyway. It takes about 30 seconds for the water to make a "lap" of the system. See my photos on this site for reference. I now have a double size CC, but other than that the engine compartment is the same.
Cheers,
Brian
Old 01-22-2007, 02:12 AM
Yep!
My Lotus Esprit
Nice motor! Seen these CC ebay once and a while. Costly affair though.
The engine is a V8, not? What turbo is it running stock?
Does the vent behind the main rad suck cool air in or drives warm air out? Never actually thought of that.
Did you find his book a good read. Quite some people find it being not technical enough. I thought it was all I needed to know, a side from some details like one way valve on the power steering vacuum, PCV valve alterations,... .
I think that is fair reasoning.
Cheers,
david
Old 01-22-2007, 06:27 PM
Cheers,
david
The engine is a Lotus built 2.2L four cyl. It's tilted over 45*. The stock turbo was a AiResearch T3 "50", and it suported 228 HP non-intercooled, and 280 HP for short bursts if the car had the intercooler installed. The time of the short burst seems to coincide with the time it takes for one coolant lap thru the CC system.
My car was originally non-intercooled. I installed the extra CC, computer, pump, header tank, pipes and radiator.
The turbo I have now is a T3/T4 hybrid.
The radiators are in a diverging area duct where the CC rad. is up front, then the A/C condensor, then the main rad. Behind that are the fans. So the air is pushed thru the duct, then sorta dribbles out the back.
Ahem..
Right now, my car has the oil cooler in FRONT of the CC radiator. I did that knowing that I'd change it later. This does not work on a hot day in Seattle!
So now, I'm in the process of changing all the plastic over in the front to move the oil cooler(s) to separate ducts on either side of the main duct to keep it from polluting the CC rad. with heat.
As an aside, some friends in Thailand (VERY hot over there) have custom built CC rads. to get rid of the heat in the CC system while toodling around Bangkok. So the rather large stock CC rad. may still not be perfect.
I think Bells book Max. Boost is good from an installation standpoint. His way of sizing the charge cooler itself seems to square nicely with what Lotus came up with stock.
Cheers.
Old 01-23-2007, 11:24 AM
didn´t know it was a four pot. The red CC mislead me ;-)
Why not a Water/oil cooler. Fits straight in the water plumbing. i.e. a Mocal cooler.
I have one at home ready for installation. Some Diesel cars have these. So you could get one fom the scrappy.
Old 01-24-2007, 07:09 PM
Theres an idea, but I've got all the new bodywork, and the oil cooler ductwork is on the way. So I'm kinda commited to doing it the one way.
