Old 01-21-2007, 03:34 AM
KiwiBacon KiwiBacon is offline
Cleaning carbon varnish.
Has anyone got a hot tip for cleaning up coked and baked oil? The stuff that has been burnt to a carbon varnish.
Specifically turbos and cylinder heads so the materials are steel and aluminium.
Old 01-22-2007, 03:42 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Cleaning carbon varnish.
Hot dip
You could also try CRC carb cleaner, its pretty corrosive.
Old 01-22-2007, 10:07 AM
534BC 534BC is offline
Oven and blast.
Old 01-24-2007, 05:36 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
if you have disassembled the heads, just use a wire wheel on a bench grinder to buff it off.
Old 01-24-2007, 11:50 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
If the motor is apart, take the pieces to a local engine rebuilder and he'll know how to clean whatever you bring in. Hot tanking steel heads always left them really clean for me.
Bob
Old 01-24-2007, 02:39 PM
Moppie's Avatar
Master Connector
Wire wheel + aluminium head =
Old 01-24-2007, 10:44 PM
Bob
I'm cleaning a motor which is together and turbo pieces which are apart.
What I'd really like to know is what do engine rebuilders use in their cleaning tanks.
I can't use a wire wheel due to too many tight corners, hand work will take a long time unless I can find an appropriate cleaner.
Old 01-24-2007, 11:42 PM
Moppie's Avatar
Master Connector
There is a mobile company that supplies the chemicals they use, they also sell and service sand plasting chambers etc.
I think its called Enviro Wash.
I think.
Old 01-24-2007, 11:45 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
i've only even known people to use paraffin to clean engines, at college we have a cleaning tank with a stiff brush which the paraffin's pumped through.
Seatbelts Saved My Life
Old 01-29-2007, 07:52 PM
79volaresw-owner 79volaresw-owner is offline
parraffin sounds good does it work that good? we got this stuff called ozzy juice same system as the parrafin i dont think it works good enough on carbon though its a enzyme but startoff with a parts washer its a big dish washer and look into a chemical dip thats aluminum safe the ones for cast iron are awesome but your aluminum will disappear if not i can amagine theres a fiber type scuffer or wheel out there that wont tear up aluminum but make sure because some can take out steel
crazy J.P here with my 79 volare stationwagon and a 93 saturn sc2 5speed with a broken tranny
Old 01-29-2007, 10:48 PM
I think.
Tergo enviro-cleaner?
Old 01-29-2007, 10:56 PM
Moppie's Avatar
Master Connector
Thats it!
Give them a ring, see if they have anything.
The guy that used to service east auck was very friendly, if its the same guy he will either have something, or know who does.
Old 01-30-2007, 01:30 AM
Thats it!
I know the stuff well, just never considered cleaning engines with it.
It's available from most protector safety shops (for some random reason).
Old 01-30-2007, 02:25 AM
Moppie's Avatar
Master Connector
They sell a whole range of different products out of thier trucks, so they have more than whats avliable through retail
