Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-21-2007, 01:52 AM
mtcs's Avatar
mtcs mtcs is offline
Send a message via AIM to mtcs Send a message via MSN to mtcs
Question Car wont start help!!! ECU problem
I lent my eclipse to my buddy and apparently he left the door open and the battery died. He tried jumping the car and I am pretty sure that that dumbass put the cables on backwards. He couldnt get it started at all. I went over and had to get it towed back to my place. I went over it and the alternator fuse was burned out. Replaced it and checked the rest of the fuses and Relays. All the other fuses were fine. I think the injectors arent getting fuel or there is no fuel to the fuel rail.
Does anyone know from experince if messing up the jump start cables could have burned out something in my Eprom ECU.
1996 ECLIPSE GST
2.3 Storker, 6 bolt, XACT flywheel, ACT Clutch, B&M shifter, DC SPORT Carbon steel strut tower bars, EVO2 exhaust, 1000cc injectors,Aeromoive rail, MBC boost controller, PTE 6152SP, SBR exhaust manifold, TIAL BOV, SBR FMIC, TEIN SS, Walbro fuel pump, AEM EMS, AEM UEGO, FP turbo intake, Aeromotive FPR, Magnus intake, 62mm throttlebody, Stoptech big brake kit, brembo rear slotted discs, Stage 2 Shep transmission (quafe), sparco fighter seats, sparco harnesses
Old 01-21-2007, 01:13 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Car wont start help!!! ECU problem
He could have seriously fucked up some major electrical shit. Do you have an extra ECU to swap in just to try (like from a buddies car or something)?
95 Talon TSI AWD
97 Eclipse GST
Old 01-21-2007, 02:21 PM
mtcs's Avatar
Nah....i dont have a spare ecu. I was going to take my ECU ouand go through it and see if all the connections are still ok. Does anyone know someonethat has a ECU I can borrow for a day or two?
1996 ECLIPSE GST
Old 01-22-2007, 01:06 AM
mtcs's Avatar
Pulled the ECU. Opened it up and looked for anything damaged or burned. Everything appeared ok. How would I go about testing my ecu to see if the ecu is the problem or not without having to swap someone else's ecu into my car?
1996 ECLIPSE GST
Old 01-22-2007, 09:28 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
I don't know how to check the ECU (other than looking for burnt spots), but I'd start assessing the problem like any other non-start problem...
What's a car need to run?
Air, Fuel, Spark (timing, etc...)
First, I'm certain that you're getting air in there...
Check the fuel pump, make sure it's pumping fuel... I pulled the line off the FPR and funneled it into a 2liter bottle... when I tried to start the car, fuel sprayed into the bottle
Next, Check spark(after reconnecting the FPR and removing the bottle and any fuel that may have spilled)... Pull a wire, have someone try to start the car... you'll be able to hear it (you can see it at night)...
make sure you pull at least two wires (best to get one's side by side, when my ignition coil went, cylinders 1 and 3 would fire, but not 2 and 4...)
If you have no spark, check the ignition coil... if that checks out, check the transistor pack...
^if you don't know how to check any of this, or what it is, let me know, I can find pics and instructions... I've just gone through a no-start situation (well, actually, still there)...
OK, actually... I typed all this without asking the major questions... so here they are:
What is the car doing?
Will it turn over?
do you hear spark? fuel pump?
any lights come on?
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 01-23-2007, 04:59 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
I almost gaurantee you that it is in the ECU.
A similar thing happened to my car and it turned out to be the ECU.
1991 GSX 2.3 Stroker
