Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 01-20-2007, 07:42 PM
TPNORTH TPNORTH is offline
Window tint removel??
I just got a 93 civic and the tint it terrible and is kinda pealing soo i had to pull it off and i got it all but now i have like adhesive stuff left on my window any idea on how to get it off?thanks
Old 01-20-2007, 10:01 PM
that_guy5's Avatar
that_guy5 that_guy5 is offline
Re: Window tint removel??
i saw this spray applicator that takes it off in auto zone u could give that a try
Old 01-21-2007, 04:49 PM
liquidlunch1812's Avatar
liquidlunch1812 liquidlunch1812 is offline
Send a message via Yahoo to liquidlunch1812
Razor blade and GooGone's how I got mine off, and it worked like a charm. The adhesive is water based, my buddy used a spray bottle with soapy water in it and a razor blade, that worked too.
Old 02-27-2007, 11:10 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
I had to use a hand held steamer and plastic scrappers to get it off. I tried a removal kit, Formula 409, GooGone, several GooGone clones, acetone, naptha, and alcohol. Nothing worked for me until I hit it with steam. Just as you found, the tint came off easy enough but, the adhesive was a SOB. Took 6 hours. In my case the stuff was on for 12 years and baked in the sun for most of that time. Use caution around the defrost pattern especially if you use razor blades.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 03-17-2007, 04:37 PM
Chevy85 Chevy85 is offline
Banned
You can also go to your local hardware store and buy a bottle of DIF it is a wallpaper remover for the home. It has enzymes in it that will eat the adhesive, usually a lot less scrapping and headache than the GooGone.
Old 03-17-2007, 05:41 PM
big tex84's Avatar
big tex84 big tex84 is offline
Get Some Aircraft Coating Remover, Be Very Cautious Any Little Drop On A Painted Surface Will Bubble The Paint Off In Like 2 Seconds All The Way Down To The Bare Surface
Finally getting my swap done, Thought I would be relieved and satisfied, now I just wanna spend money on other car parts, WHERE DOES THE MADNESS END!!!!
Old 03-17-2007, 05:42 PM
big tex84's Avatar
Its Called (ACTUAL NAME) Tal Strip 2, Find It At Advance Auto Parts
Old 03-17-2007, 10:49 PM
Banned
That Aircraft coating remover sounds like some serious stuff. Where do you pick up a bottle of that.
Old 08-19-2007, 04:38 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
retracted
