Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 01-20-2007, 04:46 PM
jimdichiara jimdichiara is offline
2003 Malibu Keyless Entry & Low Coolant
I am buying a new general motors keyless entry on Ebay for my 2003 Malibu and wanted to know if anyone knows if it can be programmed without going to the dealer.
Also I noticed many postings about low coolant lights appearing on others' Malibus. I have the same problem with the ligth turning on and off even after putting coolant in. Any suggestions?
Old 01-20-2007, 06:21 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: 2003 Malibu Keyless Entry & Low Coolant
Hopefully you got the right remote, but heres the instructions for 01 and newer...
1) Sit in the driver's seat
2) Remove the ignition key from the ignition lock cylinder
3) Close all the doors
4) Press and hold unlock on the door lock switch (on the door)
5) While holding the door lock switch in the unlock position, insert and remove the
ignition key twice. DO NOT ROTATE THE KEY.. JUST SLIDE IT IN AND BACK
OUT.
6) Insert the ignition key the third time, leaving the key in the ignition cylinder. DO NOT TURN KEY
7) Release the door lock switch. You will hear 3 chimes indicating the transmitter
programming is active.
8) Press and hold the lock and unlock buttons on the keyless entry remote at the
same time (one remote) for 12 seconds. You will hear two chimes. This indicates the
transmitter has been programmed.
9) Repeat step 8 for all additional transmitters to be programmed
10) Exit programming by removing the key from the ignition cylinder
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 10-26-2007, 04:19 PM
jocelyn1225 jocelyn1225 is offline
That Didn't Work~
Old 10-26-2007, 04:23 PM
Onblsht's Avatar
Authorized Vendor
What part number remote are you trying to use Jocelyn1225?
