Go Back   Automotive Forums Car Chat > Pontiac > Grand AM > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-20-2007, 04:32 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Post 99-03 Grand Am Parts List:Steering Column Assy/Frnt Glass/Wipers/Dash/Audio
Steering Column Assembly
1 - Colum Assy
- w/o cruise, w/o Variable assist, w/o accessort contrl
- 99 GM# 26077614
- 00-03 GM# 26074892
- W/Cruise Contrl, w/o variable assist, w/o accessory contrl
- 99 GM# 26077617
- 00-03 GM# 26098132
- W/Accessory contrl
- 99 GM# 26077615
- 00-03 GM# 26074888
- W/Cruise contrl & Variable Assist, w/o accessory contrl
- 99 GM# 26077618
- 00-03 GM# 26098133
W/Accessory contrl
- 99 GM# 26077616
- 00-03 GM# 26098135
2 - Support Bracket - 99-03 GM# 22623704
Shroud & Switches
1 - Coulmn cover
- 99-00 GM# 22610120
- 01-03 GM# 22626260
2 - Column switch(MFS) - 99-03 GM# 22676653
3 - Tilt Lever - 99-03 GM# 22611138
Housing & Components
1 -Tilt Housing - 99-03 GM# 26099572
2 -spring - 99-03 GM# 26078240
3 -Guide - 99-03 GM# 26034561
4 -Contact Plate - 99-03 GM# 26052371
5 -Upper Bearing - 99-03 GM# 26001827
6 -Bearing Spring Cam - 99-03 GM# 26055299
7 -Signal Cancel - 99-03 GM# 26099571
8 -Column position - 99-03 GM# 26049186
9 - Jacket - 99-03 GM# 26052372
10 -Housing Support - 99-02 GM# 26046405
11 -Bolt
- 99-01 GM# 26036495
- 02-03 GM# 26085842
Pin - 99-02 GM# 26036521
12 - Lower Bearing - 99-03 GM# 26052366
13 - Seat
- 99 GM# 26009849
- 00-02 GM# 26027293
14 - Spring - 99-02 GM# 7839360
15 - Position Sensor Retainer - 99-03 GM# 26064468
16 Lower Bearing - 99-03 GM# 7847029
17 Seal - 99-03 GM# 26049464
18 retainer - 99-03 GM# 26040039
19 Clockspring - 99-03 Listed in Restraint Systems
Shaft & Interanl Components
1 -Upper Shaft - 99-03 GM# 26064247
2 - Sphere kit - 99-02 GM# 26057095
- 03 Not Listed
3 -Lower Shaft - 99-03 GM# 26077595
4 Bolt - 99-03 GM# 26058124
5 Coupling shaft - 99-03 GM# 22659865
6 Boot - 99-03 GM# 22603004
Steering Wheel & Trim
1 Steering Wheel
standard wheel w/o Cruise Contrl
- 99-00 GM# 22658966
- 01-03 GM# 22625397
W/Cruise Contrl
- 99-00 GM# 22614784
- 01-03 GM# 22625394
Leather wheel w/o Accessory contrl
- 99-00 GM# 22614786
- 01-03 GM# 22625395
W/ Accessory contrl
- 99-00 GM# 22614788
- 01-02 GM# 22625396
- 03 GM# 22700271
2 -Nut - 99-03 GM# 26056108
3 - Air bag Module - 99-03 - listed in Restraint system group
4 - Horn Switch - 99-03 -(part of air bag module)
5 -Radio Control - 99-03 - included with steering wheel
6 -Cruise switch
- w/o accessory contrl - 99-03 GM# 22608615
- W/ Accessory Control - 99-03 GM# 88987045
7 Lower Shroud - 99-03 - included with steering wheel
1999 Grand Am SS 3.4 OHV
Old 01-20-2007, 04:41 PM
Post Re: 99-03 Grand Am Parts List: Front Windshield Glass-Wper Assy
Windshield
1 - Glass
GM - 99-03 GM# 22676100
NAGS - 99-03 DW01478GBN
Urethane Kit - 99-03 GM#12346392
2 - Mirror Inside
w/o Lamp - 99-00 GM#25603373
W/Lamp - 99-00 GM#22628448
- w/o commun. system - 01-02 GM# 22682764
- w/commun. system - 02 GM#22676119
- ALL - 03 GM#25603373
- bolt - 99-03 GM#10078201
3 - Mount bracket - 99-03 GM#20626174
Reveal Moldings
4 - Outer Molding
- 99-03 R GM#20626174
- 99-03 L GM#22615173
5 Upper Molding - 99-03 GM# 22611989
6 Lace - 99-03 GM#22611980
Wiper & Washer Components
1 -Wiper arm assy
- 99-03 R GM#12494808
- 99-03 L GM#12494807
2 - Cap - 99-03 GM#22127760
3 -Wiper blade
- 99-03 R GM#22614730
- 99-03 L GM#22614731
4 - insert
- 99-03 R GM#12362505
- 99-03 L GM#22155307
5 -Wiper Motor - 99-03 GM#12365366
6 - Motor Cover - 99-03 GM#12365359
7 - Transmission - 99-03 GM#12363332
8 - Seal - 99-03 GM#22062906
9 - groummet - 99-03 included in transmission & mount kit
10 - Mount Kit - 99-03 GM#12363312
11 - Crank Arm - 99-03 included in motor assy
12 -Washer Pump - 99-03 GM#22127653
seal - 99-03 GM#22062337
13 - Reservoir - 99-03 GM#12365309
14 Mount stud - 99-03 GM# 22656731
15 retainer - 99-03 GM#11518121
Level Indicator - 99-03 GM#22110978
16 Reservoir cap - 99-03 GM#12363335
17 Washer Hose - 99-03 GM#22629626
COWL
1 -Cowl top panel - 99-03 Not Serviced
2 Vent screen - 99-03 GM#22627729
3 lower frame - 99-03 Not Serviced
4 Shroud - 99-03 GM#22647428
5 Water deflector
- 99-02 GM#22645371
- 03 Not Listed
6 Dash panel Not Serviced
7 inner panel Not Serviced
8 extension Not Serviced
9 Shroud Absorber - 99-03 GM#22625528
10 Susp support - 99-03 GM#22600840
Old 01-27-2007, 02:37 PM
Re: 99-03 Grand Am Parts List:Steering Column Assembly/Front Glass/Wiper Assy
Instrument Panel(aka Dash/vents)
(Order By Color)
1 Instrument Panel
Grey
- 99-00 GM# 22627584
- 01-03 GM# 22634776
Neutral
- 99 GM# 22627585
- 00-03 GM# 22634777
Oak
- 99 GM# 22627586
2 Reinforcement
-99-03 GM# 22603603
3 Support Bracket
- 99-03 R GM# 22625031
- 99-03 L GM# 22625032
4 Panel Reinforcement
- 99-01 22632442
- 02-03 GM# 22696224
5 Seal
- 99-03 GM# 22618331
6 Defrost grill/windshield
Grey
- 99-03 GM# 22656649
Neutral
- 99-03 GM# 22656650
Oak
- 99 GM# 22656651
Side window
7 Grey -99-03 R GM# 22657916
8 Grey - 99-03 L GM# 22626904
Neutral
- 99-03 R GM# 22657918
- 99-03 L GM# 22626905
OAK
- 99 R GM# 22657920
- 99 L GM# 22657921
9 clip-windshield grill
- 99-03 GM# 15748479
10 Air Outlets(vents)
Grey
- 99-00 GM# 22652807
- 01-03 GM# 22634090
Neutral
- 99-00 GM# 22657914
Oak
- 99 GM# 22657915
Intrument Panel Components
1 Air bag Module - 99-03 listed in restraint system
2 Cluster trim
Grey
- 99-00 GM# 22611819
- 01-03 GM# 22634092
Neutral
- 99-00 GM# 22611820
Oak
- 99 GM# 22611821
clips
- 99-03 GM# 10148727
3 Accessory(radio) bezel
- w/o aux. cassette
Grey
- 99-00 GM# 22623771
- 01 GM# 22634671
Neutral
- 99-00 GM# 22623772
Oak
- 99 GM# 22623773
- W/ Aux. Cassette
Grey
- 01 GM# 22634671
Neutral
- 99-00 GM# 22616998
- 01 not listed
Oak - 99 GM# 22616999
w/o Onstar - 02-03 GM# 22675069
w/ Onstar - 02-03 GM# 22702472
4 Insulator
- 99-01 GM# 25603681
- 02-03 - included w/ accessory bezel
5 Clip - 99-03 GM# 22548453
6 Info Label - 99-03 GM# 15001744
7 Housing Lighter - 99-03 GM# 12450043
8 Lighter
- 99-01 GM# 11516146
- 02-03 GM# 11516140
9 Retainer
- 99-02 GM# 12450046
- 02-03 GM# 1999432
10 Switch Panel
Grey
- 99-00 GM# 22611804
- 01-03 GM# 22634093
Neutral
- 99-00 GM# 22611805
Oak - 99 GM# 22611806
11 clip - 99-03 GM# 16651848
12 Coin holder(garage door/opener holder)
Grey
- 99-03 GM# 22618809
Neutral
- 99-03 GM# 22611800
Oak
- 99 22611801
13 mat - 99-03 GM# 22611802
14 Outer Cover(fuse box cover(s)
Grey
- 99-01 R GM# 22618852
- 99-01 L GM# 22618853
- 02-03 R GM# 22624256
- 02-03 L GM# 22624257
Neutral
- 99-01 R GM# 22618854
- 99-01 L GM# 22618855
- 02-03 R GM# 22624258
- 02-03 L GM# 22624259
Oak
- 99 R GM# 22618856
- 99 L GM# 22618857
15 Reinforcement driver knee bolster - 99-03 GM# 22624284
B]Insulator[/b]
16 Outer
- 99-03 R GM# 22616518
- 99-03 L GM# 22678434
17 Inner
- 99-03 R GM# 22616311
Cluster & Switches
1 Cluster assy
GT
- 99 GM# 9360332
- 00 GM# 9383072
- 01-03 GM# 9383072
SE
- 99 GM# 16211672
- 00 GM# 9351732
- 01-03 GM# 9383062
Cluster Lens
- 99-03 GM# 16229674
2 Temp Control
- 99-00 GM# 9375632
- 01 GM# 9377232
- 02-03 GM# 22694864
3 Dimmer switch
- 99-00 GM# 22653124
- 01-03 GM# 22624802
4 Fog Lamp switch
- 99-00 GM# 22640031
- 01-03 GM# 22624801
5 Hazard Switch
- 99-00 GM# 22642605
- 01-03 GM# 22617983
6 traction contrl switch
- 99-00 GM# 22638514
- 01-03 GM# 22624800
7 Mount plate
- 99-02 GM# 22631181
- 03 not listed
8 Ignition Cylinder - 99-03 GM# 12458191
9 cyl bezel - 99-03 GM# 2842049
10 Ignition Switch
- 99-01 GM# 22670487
- 02-03 GM# 22688239
Air Ducts
1 Defrost nozzle
- 99-03 GM# 22601972
2 retainer
-99-03 GM# 10121502
3 seal
- 99-03 GM# 22641209
4 Air distributor
- 99-03 GM# 22614949
Defrost duct
side window defogger
5 - 99-03 R GM# 22611984
6 - 99-03 L GM# 22610968
7 retainer - 99-03 GM# 10121502
Defrost grill
8, 9, 10, 11 Windshield/ side window & air outlet(vents)
- 99-03 - included w/ instrument panel, listed in Instr. panel group.
12 Outlet duct - floor air
w/o air duct - 99-03 GM# 22596516
w/air duct - 99-03 GM# 22602635
13 Air duct -99-03 GM# 22596517
14 Floor duct - 99-03 R GM# 22619820
15 Floor duct - 99-03 L GM# 22619821
Glove Box
1 Glove box assy
w/o door - 99-03 GM# 22612402
W/ door
Oak - 99 GM# 22619861
Grey - 99-02 GM# 22619759
Neutral - 99-02 GM# 22519760
All - 03 Not listed
2 Glove box door - 99-03 included with glovebox assy
3 Compartment - 99-03 GM# 22612402
4 Bumper - 99-03 B GM# 22652418
5 Hinge pin - 99-03 GM# 21040841
6 retainer - 99-03 B GM# 21040861
7 Striker - 99-03 GM# 22613647
8 Latch - 99-03 GM# 22625037
9 Lock cylinder - 99-03 GM# 12514483
10 - Handle
Oak - 99 GM# 16760524
Grey
- 99-02 GM# 25648154
- 03 GM# 22701621
Neutral
- 99-02 GM# 16758450
- 03 GM# 22701622
11 retainer - 99-03 GM# 25557367
12 Glove box lamp - 99-03 GM# 12450028
Sound System
1 Radio
AM/FM stereo
- 99 GM# 16180982
- 00 GM# 9359309
AM/FM CD player
- 99-00 GM# 9390772
- 01 GM# 10318435
- 02 GM# 10318435
Am/Fm Cassette
- 99-00 GM# 9376112
- 01 GM# 10311737
- 02 GM# 10318440
- 03 Not listed
2 Cassetter Player - 99-00 GM# 9374952
3 bracket - 99-00 GM# 22657179
Speakers
4 Upper front door tweeter - 99-03 B GM# 9353789
5 - Front door -(order by description)
4 speaker system
- 99 B GM# 16209359
- 00 B GM# 9390419
- 01-02 B GM# 22679880
6 speaker system
- 99-01 B GM# 22679881
- 03 B GM# 22696918
8 speaker system
- 01 B GM# 9377979
- 02 B GM# 22679882
- 03 B GM# 22696919
6 - Rear Speaker
- 99-02 B GM# 9374451
subwoofer
- 99-00 B GM# 9374599
- 01-03 B GM# 22698418
7 -Amplifier
- 99-00 GM# 9378542
- 01-03 GM# 22674744
Console
1 Console Assy
Oak
- 99 GM# 12365298
Grey
- 99-00 GM# 12365296
- 01 GM# 88892585
- 02-03 GM# 88892729
Neutral
- 99-00 GM# 12365297
- 01 GM# 88892584
- 02-03 GM# 88892730
2 Center bracket - 99-03 GM# 22623907
3 Rear bracket - 99-03 GM# 22618761
4 Armrest Assy
Grey - 99-03 GM# 12365291
Neutra - 99-03 GM# 12365292
Oak - 99 GM# 12365293
5 Hinge - 99-03 GM# 22647466
6 Latch
- 99-01 GM# 22644675
- 02 - included in armrest assy
7 Trim Plate
Oak - 99 GM# 22601817
Grey
- 99-00 GM# 22616582
- 01-02 GM# 22675305
Neutral
- 99-00 GM# 22601816
- 03 not listed
8 Mat
- 99-00 GM# 22647446
- 01 GM# 22628955
- 02-03 GM# 22675303
9 Ashtray- 99-03 GM# 22611364
Mat compartment
- 99-00 GM# 22647464
- 01-03 GM# 22628956
10 Cup holder
Grey - 99-03 GM# 12463109
Neutral - 99-03 GM# 12463110
Oak - 99 GM# 12463111
Parking brake Boot
- 99-00 GM# 22604010
- 01-03 GM# 22662075
Closed Thread
