Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 01-20-2007, 04:17 PM
sparky5997 sparky5997 is offline
door panel
does anyone know how to remove the door panel on a 92 olds cutlass supreme. I need to try to fix the door handle thanks mark
Old 01-20-2007, 05:23 PM
gcutllass gcutllass is offline
Re: door panel
If you are in need of replacing the exterior handle you will not need to remove the interior trim panel. All can be done through the acces panel that covers the linkage. You need to be more specific as to which handle you are working on.
to remove an interior trim panel several mounting screws must be removed and retaining clips loosend then the panel must be pulled upwards towards the window for there are plastic guide fingers at the bottom of the panel.
hope this helps
Good Luck
Gcutllassn
Old 01-20-2007, 05:36 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: door panel
Welcome to AF sparky5997 !
Try here for you door needs
Look to the right you will see door panel
1999 Grand Am SS 3.4 OHV
