Old 01-20-2007, 12:53 PM
mjtr21 mjtr21 is offline
4wd actuator
Does anyone know where I can buy the 4WD Actuator? I went to Advanced Atuo and AutoZone and neither had it and said they wouldn't be able to get it. So I need help. Thanks in advance.
Old 01-21-2007, 12:43 AM
JaVeRo JaVeRo is offline
Re: 4wd actuator
The dealer or a local parts place that gets ACDelco parts.
Old 01-21-2007, 10:13 PM
Re: 4wd actuator
Thanks. I am going to check with the dealer tomorrow and see how much that part is.
Old 01-22-2007, 09:15 AM
herkyhawki herkyhawki is offline
Re: 4wd actuator
Both Autozone and Advanced have this part, or can get it in 1-2 days, for about $50. It's a Dorman part #. I'll post the # later. The problem is that the idiots at the parts stores don't know what there doing.
Old 02-02-2007, 03:57 PM
Re: 4wd actuator
so did anyone ever find the part number because its snowing out here and it sucks being stuck in my own driveway.
Old 02-02-2007, 04:05 PM
muddog321 muddog321 is offline
AF -Advisor
Re: 4wd actuator
Dorman #600-102 (often for search skip the "-" or 600102) or GM #25031740.
But make sure that's it cause would suspect the 3 port vac switch on the transfer case or a rotted out vac line first.
Old 02-06-2007, 09:37 AM
duke350 duke350 is offline
Re: 4wd actuator
NAPA also has this part and is usually better then the autozone type places.
Old 02-07-2007, 02:42 PM
Re: 4wd actuator
it sholdnt be the vacuum i had that replaced and i know it's on right. the actuator has a tear in it so i know it's the cause of my problem. ill try NAPA because AAP and AZ say they cant get it from their factory anymore or some other excuse. thanks.
