Old 01-20-2007, 03:04 AM
jcsaleen's Avatar
jcsaleen jcsaleen is offline
Do rim sizes effect wheel hp?
Do rim sizes effect horsepower to the wheels? Ex. a stock 16 Vs 18 inch rim because of the whole diameter - enertia thing? Also does weight play a factor?
Thanks
Jcs
"Driving a Mazda RX7 on the track for the first time was very cool ? this is a production car that most
resembles the movement of a formula car in my experience so far.
" ~ Igor
Old 01-20-2007, 10:54 AM
GreyGoose006 GreyGoose006 is offline
Re: Do rim sizes effect wheel hp?
well it will effect the unsprung weight and rotating inertia.
higher rotating inertia will definitely slow you down.
more unsprung weight will make your suspension less precise because it has to work harder.
you say you are into drag racing?
if i were you i'd get the lightest wheel i could find.
Old 01-20-2007, 04:56 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
Were you to show up at a Dyno Jet type of chassis dyno (inertial), and change from a light wheel and tire combo to a heavier wheel and tire combo, you would show a loss of rear wheel horsepower--even though the engine was making the same power in both tests.
Which accurately relects what would happen at the racetrack, unless the heavier combo has more traction than the lighter combo, then the car might be faster.
A tradeoff that people with high power cars gladly make.
Old 01-20-2007, 05:23 PM
UncleBob UncleBob is offline
AF -Advisor
as far as diameter, it changes final gearing ratio, which doesn't effect the HP of the engine, but it can definitely effect acceleration.
Keep in mind though, just going to a larger diameter rim, doesn't necessarily mean the total diameter of the tire is larger....it depends on what tire you use. Sites such as tirerack.com has diameter measurements for all their tires, if you wish to compare the before/after options
Rim/tire weight has a very large effect on acceleration. Too often people put those cheasy aftermarket rims on that add 100+ pounds to the rotating mass. Not only does this have a very negative effect on acceleration, it also reduces the braking ability.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 01-20-2007, 05:51 PM
jcsaleen's Avatar
Hmm yea I was looking at forged rims from volk. (Te37's in 18x10 in the back 8.5 in the front)
" ~ Igor
Old 01-21-2007, 12:18 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Volk GT-Cs would look better than TE-37s on an RX-7, just my opinion.
Seatbelts Saved My Life
Old 01-21-2007, 03:47 PM
jcsaleen's Avatar
they only look good on silver or white they suck on MB's white is a contrasting color to dark.
" ~ Igor
Old 01-22-2007, 09:28 PM
sv650s's Avatar
sv650s sv650s is offline
Send a message via AIM to sv650s Send a message via MSN to sv650s
what about ce28n's? lighter weight for a little more money + they look perfect on an fd
Old 01-25-2007, 02:13 PM
jcsaleen's Avatar
Not really into Ce28's my friend has them on his R1 it looks so so but not my style.
" ~ Igor
