Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-19-2007, 08:02 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
P0446 and P1450
Heres the codes im getting.
Problem 1: Troubleshooting code P0446
diagnostic equipment:
"The PCM has determined that a malfunction exists in the electrical circuit for the vent control in the evaporative emission control system".
Me:
"Say what? Does that mean my charcoal canister is bad?"
Problem 2 : Troubleshooting code P1450
"Unable to bleed up fuel tank vacuum".
ME:
I think i have a bad gas cap. I have noticed that the gas tank makes a noise often. It seems to me vacuum pressure is building in the tank and then the cap suddenly allows air into the tank after its built up a bunch. Half the time after it makes this noise as soon as you roll up to the next light it sputters, and dies. Also, when i take the gas cap off the car at a filling station, when i remove the cap i hear the tank take in a big breath of air. Could this be a possible explanation to the P1450 code?
What are these codes exactly, and what do i need to replace?
Old 01-20-2007, 04:52 PM
fleettech fleettech is offline
Re: P0446 and P1450
chances are very good you have a bad cap. we have had a bunch go bad.
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
Old 01-20-2007, 07:34 PM
Re: P0446 and P1450
what about the P0446 code?
Old 01-25-2007, 01:48 AM
reekor reekor is offline
Re: P0446 and P1450
Sounds like a bad purge value or a plugged gas return line on both codes.
Me:
ME:
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 02-16-2007, 08:25 PM
Re: P0446 and P1450
Update.
It wasnt the purge valve or canister. Or the gas cap. i thought i had it fixed when i changed out all three but eventually the CEL came back on. I havent had the codes scanned again as of yet but im sure its going to be the same problem. It must have a clog somewhere. Once i figure out what the problem is i will post it up for any who are wondering what can possibly set these codes. I guess i will unhook the line on both ends and shoot some air down them and see if its clogged.
