Old 01-19-2007, 07:09 PM
harpes620 harpes620 is offline
Sons 92 Blazer NO 4X4 lights Please Help
My son has a 92 S-10 Blazer. The 4X4 was working fine until it snowed and now the lights on the switch will not come on at all. I am hoping its some kind of fuse etc. but figure it will cost him more than he paid for the blazer. I bought a chiltons book but it didnt even mention this switch. If someone can give me a good idea and keep it in english we would both be grateful. I dont have anyway of reading codes. I saw on the forums that something called tccm fuse might be the problem but I dont know where to even look.
Thanks
Old 01-19-2007, 07:15 PM
1996LTOwner 1996LTOwner is offline
Re: Sons 92 Blazer NO 4X4 lights Please Help
Just because the light does not come on does not mean it isn't in 4WD. Try to make a slow but sharp turn, if the truck feels like it's pushing against something, it's in 4WD and you just have a burned out bulb.
Old 01-19-2007, 08:06 PM
The four wheel drive doesnt even to engage. He was stuck in the snow today so I got to see it wasnt working. There is no clicking like the transfer case is trying to engage or anything.
Old 01-19-2007, 10:48 PM
JaVeRo JaVeRo is offline
Is this a floor shift or push button? Being a 92 I would guess a floor shift.
Put it in 4hi and try turning the front driveshaft. If it is locked then the transfer case is probably good and the problem is with the front acutator.
James
Old 01-20-2007, 08:24 AM
Its push button on the dash, auto tranny and the vortec 4.3.
Old 01-20-2007, 08:29 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
First thing to check would be vacuum lines.
I had one come off the vac cannister on mine, causing the 4wd
not to work.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 01-20-2007, 08:59 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
vacuum actuator under the battery.
Check vacuum lines.
Check all fuses.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-20-2007, 09:50 AM
Thanks I'm getting ready to tear into it. It just doesnt make since, the indicator lights dont even come on when you first turn on the key.
Old 01-20-2007, 11:36 AM
Check the fuses first. If the lights are not coming on, it's not getting power (or a bulb is burned out). If it's not getting power, nothing is gonna work.
James
Old 01-20-2007, 05:05 PM
Bingo it was the radio fuse. He had installed an aftermarket sound system in the fall. 1 minute fix and less than a buck. Thanks Everyone. Cant figure out why the hell the 4X4 switch is protected by the radio fuse?
Old 01-20-2007, 06:35 PM
BlazerLT's Avatar
AF -Advisor
ok, hope you didn't put in a larger fuse.
