Old 01-19-2007, 01:43 PM
SlackerOfSociety's Avatar
SlackerOfSociety SlackerOfSociety is offline
Sub problem
I just hooked up a system in a friends car. He has a profile ap1200 2 channel amp. Only one sub is working, all wires are hooked up correctly, and both subs worked on his old amp. Could it be a blown fuse, or if that was the case wouldnt none of the subs work? Please help!
Old 01-19-2007, 02:17 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: Sub problem
maybe a fuse in the amp is blown. i don't know if one blows (assuming there are two+ in the amp) it only affects one channel or both. check them.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 01-19-2007, 02:32 PM
Re: Sub problem
nevermind the problem is fixed for some odd reason???
Old 01-19-2007, 02:42 PM
bjboertje's Avatar
Re: Sub problem
loose connection maybe?
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 04-30-2007, 06:39 PM
ugamikej07 ugamikej07 is offline
Re: Sub problem
hey i have two 12'' alpine type E with a 1000 watt kenwood amp.I recently started hearing like a dog panting kinda noise from my subs.They still hit hard,could it be the box?i have a couple of screw holes from where i moved my amp on the box
Old 04-30-2007, 11:33 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: Sub problem
Sounds like an air leak. Could be anything. Fist plug the holes where the amp was with screws. If that isnt it. Get non-drying silicone for the sub and make a gasket in between the enclosure and sub.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
