Old 09-26-2002, 08:07 AM
Daryl's Avatar
Daryl Daryl is offline
Scored on this today!
I was debating whether or not to post this in the die-cast forum, but since i'm treating it like any other plastic model, i thought i'd post it here. It's a Bburago alfa 156 police car diecast kit which i'm gonna convert into this
Never customised a diecast before, and this is the only kit of a 156 that i could find after searching high and low... well, here goes nothing...
Left is right. Right is wrong.
Old 09-26-2002, 09:06 AM
Guido Guido is offline
aha, a 156 GTA, sweet!
Looking forward to the transformed end-result
Old 09-26-2002, 09:13 AM
Veyron's Avatar
Veyron Veyron is offline
Wink Alfalfa
I have one of those too, only mine is the regular street version. I haven't rebuilt it yet but I'm sure they can be nice.
Old 09-26-2002, 10:21 AM
ZoomZoomMX-5's Avatar
I've got that one too
I've got a pukey green street version, and I want to do a similar build of it. With a little TLC and "modelers charm" nobody will know the difference what material it's made of. Bburago did a decent job on it, the lines look good.
Maybe the three of us gang up and work on them at the same time? I can't for a while though...
Old 09-26-2002, 11:04 AM
flyonthewall's Avatar
Car Mod guy
Looks cool! Be good to do the race version too. BBBBBBurago seem to have done a good job...for a change!
Old 09-26-2002, 11:45 AM
Daryl's Avatar
There's lots of *extra* panel lines, so much for BbBbBburago doing a decent job... man it's gonna be a bitch to sand down mold lines on diecast........
Old 09-26-2002, 12:33 PM
freakray freakray is offline
AF Modelrater
One word......Dremel
Or 2 words......Motor Tool
Should make life a lot easier with the sanding drum thingy....just my .02c
AF User Guidelines
Old 09-26-2002, 01:17 PM
Smile It's not difficult removing mold lines w/the correct tools
Not exactly-I tried removing the mold lines on a metal body car, and I used a flat file and some sanding sticks, and it smoothed out beautifully. Metal isn't that difficult to work with if you have the right tools, and it cuts very smoothly and you won't go too far too fast like you can with plastic. After that, and cutting a roof off of a metal car w/my Dremel and a cutting wheel, diecast doesn't scare me whatsoever.
Strip the paint with some aircraft/automotive paint stripper. I got a can at Wal Mart, and the paint bubbled off the metal in seconds. Be careful w/it (don't let it on you, anything plastic, your skin, your clothes, or you lungs), but after it's clean and dry start removing the mold lines w/a file and finish up the areas w/sanding sticks or sandpaper. Only in extreme cases (such as hollow areas where a file or sandpaper won't reach) should you need to resort to using a Dremel.
Old 09-26-2002, 02:03 PM
Car Mod guy
A bigger problem will be in filling that hole on the roof. Might be worth you checking out some of the sites of people who customize Hot Wheels coz they do quite alot of tricky filling and bonding. I think they use something called JB Weld??? Heard of it???
Old 09-26-2002, 02:09 PM
I know what it is, though I haven't used it yet. It will work, I would fill the area w/a piece of sheet styrene bonded w/JB Weld or superglue, then use "standard" catalyzed (two part) spot putty to fill the gaps. A piece of tape underneath can hold the plastic in place while it's being adhered to the metal w/the glue or the epoxy.
I'm glad I got the street version, no holes to fill!
Old 09-26-2002, 08:47 PM
Looks like a nice project.
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 09-27-2002, 01:12 AM
_835_'s Avatar
_835_ _835_ is offline
Send a message via ICQ to _835_ Send a message via Yahoo to _835_
Nicely, that s one project i have in my head : modify a bburago or a diecast, as the car i want doesn't exist in plastic...and a complete resin kit is too expensive... keep us inform of how nice it is to modified a die-cast.
Thanks a lot !!
_835_ from ASPHALT models
IN PROGRESS / WAITING Too much to list all And so many project in my head....
98 4x4 blazer cause of new rotor scoring? roadtrips Problem Diagnosis 1 07-18-2010 08:39 AM
This menu uses javascript This menu uses javascript This menu uses ... - Lancaster Today Automotive News Automotive News Desk 0 05-22-2006 06:30 AM
Scored at the local salvage yard today!! scottsee Off-Topic 2 11-01-2005 09:14 PM
Got this today Tuner Car Modeling 17 05-13-2003 11:34 PM
