Old 01-19-2007, 09:10 AM
chldzpla chldzpla is offline
Headlight Choice for 1991
I find my current headlight to be rather dim and so is the fog light.
What is your choice for replacements to acheive a better beam on a 1991 3000GT VR4? Thanks!
Dan
Old 01-19-2007, 11:19 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Headlight Choice for 1991
very good observation. the light output is awful. in short, you have a few options:
-upgrade to an aftermarket 4x6 housing so you can change bulbs (referred to as the H4 Conversion)
-HID Kit with the aftermarket 4x6 housing
-HID retrofit.
here is a thread where i've explained the differences: http://www.3si.org/forum/showthread....&highlight=hid
HID Kit pics
info on the basics of HID lighting
here's a guy who did a retrofit on his 1st gen stealth (92) with pop ups
http://www.3si.org/forum/showthread.php?t=291237
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-19-2007, 11:47 AM
I am impressed with your dialogue!
The difference is quite dramatic. I wish I could just click and pay and get all that I needed with a good set of instructions.
Old 01-19-2007, 12:09 PM
Linebckr49's Avatar
i guess that's one, if not the only, thing a college education gets you, lol.
if you are interested in a retrofit, which will yield the absolute best lighting possible right now (made available by latest, most current technology), then it would be worlds easier for you to do the "2nd Gen Conversion" and retrofit those headlights (that came on 3000GTs from 94-98). i did a 2nd gen retro for a guy in probably just 20 hours of total labor. much easier than my current retrofit into the pop-ups. however, i love the pop-up look, so that's why i'm keeping it.
also, i've heard very good things about the 2nd gen headlights and HID kits. that's not the way for me, but it is a very viable option for those who don't wish to invest a lot of money and even more time into a retrofit. plus, the 2nd gen headlights receive the HID kits well and put out a decent pattern with very improved illumination.
93 3000GT base
Old 01-19-2007, 12:58 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
If you don't want to spend the time or money on an HID conversion the Sylvania Silverstars are only $20 a bulb. I just put them in my car and they are much brighter than the bulbs I had in there before.
Old 01-19-2007, 01:18 PM
Linebckr49's Avatar
true, they are just 20 a bulb, but the stock pop-up headlamps are sealed beam units, which cannot have bulbs swapped in/out. he will need to get an aftermarket 4"x6" housing, then he can get the silverstar bulbs. also, a wiring adapter will be needed.
93 3000GT base
Old 01-19-2007, 04:52 PM
Polygon's Avatar
The Red Baron
Huh?
Silverstar makes a sealed beam version for the first gens. I just bought a set for my 91' and they swap right in.
Old 01-19-2007, 05:04 PM
Linebckr49's Avatar
oh. i didn't know they made a sealed beam unit. you said bulb, so that made ME think "huh?" lol.
93 3000GT base
Old 01-19-2007, 10:37 PM
Polygon's Avatar
The Red Baron
Oh, whoops.
Yeah, I should have said sealed beam since they aren't bulbs.
Old 01-20-2007, 12:21 PM
vectorspecialist vectorspecialist is offline
eh, i just drive with highbeems on, ppl never complian, and its much brighter, but yea, without them on it is pretty dull, worse yet, mine arent even centered, it's like a cross eyed person lighting up the road.( NO OFFENSE BY THE CROSS EYED THING ITS JUST WHAT ITS LIKE)
Old 01-20-2007, 02:14 PM
TorchedStealth's Avatar
TorchedStealth TorchedStealth is offline
Send a message via MSN to TorchedStealth
I always thought my stock lights were pretty bright. I always have my foglights on when my low beams are on and ive had a lot of people flash me because they think my brights are on. Then i flash them to show them that the highs arent on yet and they stop flashing me lol. When i drive behind my friends they like me to have my fogs off so its not so bright and sometimes just to be mean i turn on my brights and they say they are really bright, so idk. But i only do that to my friends, i dont want you guys to think im an ass t everyone. I think they are stock but they are sylvania so idk if thats what they had stock but i know they arent silverstars.
2005 Saturn Ion Redline - Injector Dynamics 1000cc Injectors|E85|Harrop TVS1320 Blower|2.9" pulley|3" Intake|Vibrant Header and catless Downpipe|Hahn 3" catback|N2MB Wot Box w/2-step and no-lift shift|Cobra Heat Exchanger|Hurst STS|Ottp Stage 1 trans mounts|AEM EUGO Wideband|Aeroforce Interceptor|HPTuners (self tuned)|Mop Top Pros Carbon Fiber badges|B&G Springs
Old 01-20-2007, 03:24 PM
Linebckr49's Avatar
its probably not that your light seem so bright to other drivers, but rather that your lights aren't aimed properly, and are shining too high and blinding other drivers. you might check this out. go drive to a flat place in the dark, park you car 25 feet from a wall. at 25 feet, the top of your beam should drop 2.1-2.5 inches. measure from the center of your headlight. if too low, then measure from the top of your headlight. just be consistent.
93 3000GT base
Old 01-20-2007, 05:56 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
the stock headlamps are fairly dull when it comes to output, So the first thing i did to my car was get the H4 conversion kit, it was really easy to install, and even with the super cheapo bulbs that the kit came with there was a drastic improvement in lighting.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 01-22-2007, 04:02 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
please try not to use your high beams, not everyone has the best eyes at night and high beams can really throw someone's vision off, even wearing glasses...it does cause accidents
Old 01-22-2007, 08:43 AM
Wonderful input all. Thank you. It sounds like this is (see below) the way to go for the long term; however, the sealed beam Syvania Silverstar seems like a short term good fix that is inexpensive. I believe the latter is my choice. Again, thanks for all the input and good thoughts. Can I buy these bulbs at the auto parts store or is it special order?
Dan
-HID retrofit.
HID Kit pics
