Go Back   Automotive Forums Car Chat > Pontiac > Grand AM > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-18-2007, 09:03 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Post 99-03 Grand Am Parts List: Exhaust-Emissions/Front Suspension/Power Steering
Exhaust components
2.2
Exhaust Manifold -02-03 GM# 90537679
gasket -02-03 GM# 90537696
Heat shield - 02-03 GM# 90537953
1 Converter pipe - 02-03 GM# 22676850
2 stud - 02-03 GM# 10160364
3 nut - 02-03 GM# 11517996
4 Gasket
front - 02-03 GM# 24576511
rear
GT - 02-03 GM# 22545047
SE - 02-03 GM# 88891788
5 Internal pipe - 02-03 GM# 22609731
6 hanger - 02-03 GM# 22659363
7 clamp - 02 GM# 14103715
8 Muffler & pipe - 02-03 GM# 22657995
9 hanger - 02-03 GM# 22659362
Heat shield
10 converter - 02-03 GM# 22618965
11 intermidiate pipe - 02-03 GM# 22634637
12 Muffler - 02-03 GM# 22648469
13 bracket - 02-03 GM# 22681621
exhaust 2.4L
1 exhaust manifold
- 99 GM# 24574871
- 00-01 GM# 24576614
2 gasket - 99-01 GM# 24576382
3 heat shield
- 99 GM# 24575345
- 00-01 GM# 12564081
4 bracket 99-00 GM# 24574112
5 stud - 99-01 GM# 24576687
6 nut - 99-01 GM# 10255857
7 Converter & pipe
- 99-00 GM# 22667029
- 01 GM# 22667029
8 gasket
front - 99-01 GM# 24576511
rear
- GT - 99-01 GM# 22545047
- SE - 99-01 GM# 88891788
9 Intermed pipe - 99-01 GM# 22609731
10 hanger - 99-01 GM# 22659363
11 clamp - 99-01 GM# 14103715
12 muffler & pipe - 99-01 GM# 22657995
13 hanger - 99-01 GM# 22659362
Heat shield
14 converter - 99-01 GM# 22618965
15 intermed pipe - 99-01 GM# 22648470
16 muffler - 99-01 GM# 22648489
bracket
17 Converter - 99-01 GM# 22681621
18 intermed pipe - 99-01 GM# 22647448
Exhaust Components 3.4
1 Exhaust Manifold
- 99-03 R GM# 24506309
- 99-03 L GM# 10182321
2 gasket - 99-03 GM# 24504632
Heat shield
right side
3 Upper - 99-03 GM# 24508294
4 Lower - 99-03 GM# 24506295
5 Left side - 99-03 GM# 10182323
6 Crossover pipe - 99-03 GM# 24507946
7 Heat shield - 99-03 GM# 10236641
8 stud
- 02-03 GM# 22604451
9 Nut - 99-03 GM# 10255857
10 Converter & pipe
GT
- 99 GM# 24508312
- 00 GM# 12563203
- 01-03 GM# 25325206
SE
Federal - 99 GM# 24507291
- 00 GM# 24508312
- 01-03 GM# 22685817
11 gasket
front - 99-03 GM# 24505057
rear
- GT - 99-03 GM# 22545047
- SE - 99-03 GM# 88891788
12 Intermed pipe
- GT - 99-03 GM# 22608891
- SE - 99-03 GM# 22657998
13 Hanger - 99-03 GM# 22659363
14 Clamp - 99-02 GM# 14103715
15 Muffler & pipe
- GT - 99-03 GM# 22657994
- SE - 99-03 GM# 22657995
16 Hanger - 99-03 GM# 22659362
Heat shield
17 converter - 99-03 GM# 22618965
18 Intermed pipe
- 03 GM# 22634637
19 Muffler - 99-01 GM# 22648469
-GT - 02-03 GM# 22657994
-SE - 02-03 GM# 22657995
Bracket
20 Converter - 99-03 GM# 22681621
21 Intermed pipe
- 02-03 *not serviced
Emission Components
1 Egr Valve
- 2.4L 99 GM# 17113712
- 3.4L 99 GM# 17113285
00-03 GM# 12565309
2 Gasket
- 2.4 99 GM# 21006754
- 3.4 99 GM# 24506439
00-03 GM# 24506939
3 Adapter
- 2.4 99 GM# 24574624
4 Gasket 99 GM# 24573947
5 EGR Pipe
- 2.4 - 99 GM# 24574464
- 3.4 - 99 GM# 24506775
- 00-03 GM# 24508969
6 MAP Sensor
- 2.4 99-01 GM# 16231423
- 3.4 99-01 GM# 16254719
02-03 GM# 12569240
7 Oxygen Sensor
- 2.4L - 99 GM# 2516200
-00-01 GM# 24577622
- 2.2L
-to manifold 02-03 GM# 12568234
-to converter 02-03 GM# 12568222
3.4L 99-01 GM# 25312203
-to manifold 02-03 GM# 12559850
-to converter 02-03 GM# 25312206
8 Knock Sensor
- 2.4L 99-01 GM# 24577244
- 2.2L 02-03 GM# 24577244
- 3.4L 99-03 GM# 10456238
9 Vapor Canister 99-03 GM# 17113329
bracket 99-03 GM# 22645687
10 Shield 99-03 GM# 22642642
11 Solenoid Valve 99-03 GM# 22622023
12 bracket 99-03 GM# 22650106
13 Purge Valve
- 2.4L - 99 GM# 1997201
- 00-01 GM# 1997278
- 2.2L - 02-03 GM# 1997278
- 3.4L - 99 GM# 1997210
- 00-03 GM# 1997297
14 bracket
- 2.4L - 99 GM# 24575961
- 00-01 GM# GM# 24576404
- 2.2L - 02-03 GM# 24577483
- 3.4L - 99 GM# 12563459
1999 Grand Am SS 3.4 OHV
Old 01-19-2007, 05:32 PM
Post Re: 99-03 Grand Am Parts List- Front Suspension/Power Steering
Front Suspension
1 -Hub & Bearing - 99-03 B GM# 12429202
2 -mount bolt - 99-03 GM# 18022052
3 -Wheel Bolt - 99-03 GM# 9591978
*Speed sensor(included w/Hub/bearing)
4 -Rotor - 99-03 B GM# 18060442
5 Caliper
- 99-03 R GM# 18026209
- 99-03 L GM# 18026208
6 Bolt - 99-03 GM# 18023069
7 -Splash shield
- 99-03 R GM# 18025959
- 99-03 L GM# 18025958
8 -Brake Hose - 99-03 B GM# 22163193
9 -Brakes Pads
-99-02 GM# 18024383
-03 GM# 18044437
Suspension Components
1 -Knuckle
-99-03 R GM# 18060675
-99-03 L GM# 18060674
2 -Lower Control Arm
W/O Sport suspension
- 99 R GM# 22609742
- 99 L GM# 22609743
- 00-03 R GM# 22625030
- 00-03 L GM# 22625029
W/Sport susp-
- 99 R GM# 22609744
- 99 L GM# 22609745
- 00-03 R GM# 22626332
- 00-03 L GM# 22626333
3 -Front Bushing
w/o sport susp - 99-03 B GM# 22645684
W/Sport susp - 99-03 B GM# 22645683
4 -Rear Bushing - 99-03 B GM# 22610297
Bolt
5 -Front - 99-03 B GM# 22657679
6 -Rear - 99-03 B GM# 11518122
7 -Lower Ball Joint - 99-03 B GM# 22157023
8 -Strut
- GT - 99 B GM# 22064770
- SE - 99 B GM# 22064731
- All - 00-03B GM# 22064788
9 -Mount
- GT - 99-02 GM# 22178510
- SE - 99-02 GM# 22146949
- All - 03 GM# 22200754
10 -Nut - 99-00 GM# 11514596
- 01-03 GM# 22123946
11 -bolt - 99-03 GM# 11515754
12 - Spring Seat - 99-03 B GM# 22177853
13 - Upper insulator - 99-03 B GM# 22165310
14 - Spring - 99-03 B GM# 22132938
15 - Shield - 99-03 B GM# 22152205
16 - Bumper - 99-03 B GM# 22177920
17 - Lower Insulator -99-03 B GM# 22152176
18 - Mount Bolt - 99-03 GM# 22600725
19 - Nut - 99-03 GM# 11516382
Suspension Mounting
1 - Engine Cradle - 99 GM# 22626334
Manual trans - 00-03 GM# 22643963
Auto trans - 00-03 GM# 22626334
Bolt
2 -Front - 99-03 B GM# 22615143
3 -Rear - 99-03 B GM# 11518122
4 -Tension Plate - 99-03 B GM# 11515767
5 - nut
- 99-03 R GM# 22605694
- 99-03 L GM# 22605695
6 - Retainer - 99-03 GM# 22610109
Stabilizer Bar & Components
1 - Stabilizer bar - 99-01 GM# 22603564
- w/o Sport Susp - 02 GM# 22595741
- W/Sport susp - 02 GM# 22603564
- All - 03 GM# 22595741
2 - Stabilizer Link - 99-03 GM# 22657717
3 - Insulator - 99-03 GM# 22619843
4 - Bracket - 99-03 GM# 22660396
Drive Axles
1 - Axle shaft Assy
Auto trans
- 2.4L - 99-01 B GM# 26059860
- 2.2L - 02-03 B GM# 26059860
- 3.4L - 99-03 B GM# 26091316
Manual Trans
- 00-03 R 26077124
- 00-03 L 26077123
2 - Retainer Ring - 99-03 B GM# 24205145
3 - Shaft
Auto trans
- 2.4L 99-01 B GM# 26039298
- 3.4L 99-01 B GM# 26066792
Manual trans
- 00-01 R 26079607
- 00-01 L 26079606
All 02-03 B *part included with shaft assy
4 -C.V. Joint - 99-01 B GM# 26059845
- 2.2 L - 02-03 B GM# 26059845
- 3.4 L -02-03 B GM# 26091313
5 - Inner Joint
Auto trans
- 2.4L - 99-01 B GM# 26039289
- 2.2L - 02-03 B GM# 26039289
- 3.4L
- 99-01 B GM# 26066722
- 02-03 B GM# 26091315
Manual Trans -00-03 B GM# 26079536
6 - Outer Boot - 99-01 B GM# 26059842
- 2.2 L - 02-03 B GM# 26059842
- 3.4L - 02-03 B GM# 26044380
Clamp
7 - Outer - 99-02 B GM# 7848882
8 - Inner - 99-01 B GM# 7848880
-2.2L - 02-03 B GM# 7848880
-3.4L - 02-03 B GM# 26040573
9 - Inner Boot
- 2.4L - 99-01 B GM# 26035041
- 2.2L - 02-03 B GM# 26035041
- 3.4L - 99-03 B GM# 26091312
Clamp
10 - Inner - 99-01 B GM# 7848880
- 2.2 L - 02-03 B GM# 7848880
- 3.4 L - 02-03 B GM# 26040573
11 - Outer - 99-01 B GM# 7847740
- 2.2 L - 02-03 B GM# 7848840
- 3.4 L - 02-03 B GM# 26075674
13 - Bushing
- 2.4 L - 99-01 B GM# 26041868
- 2.2 L - 02-03 B GM# 26041868
- 3.4 L 99-03 B GM# 26053279
14 Bearing Assy - 99-03 B * included in axle shaft assy
Steering Gear & Linkage
1 - Gear Assy
- w/o variable assist - 99-02 GM# 26073992
- w/ variable assist - 99-02 GM# 26086616
- All - 03 GM# 26076992
Insulator - 99-03 GM# 100062902
- Sleeve - 99-03 GM# 14088178
- Bolt - 99-03 GM# 22657705
2 - Outer Tie Rod
- 99-01 B GM# 26055104
- 02-03 B GM# 26086073
3 - Inner Tie Rod
- w/o Variable Assist - 99-01 B GM# 26073562
- w Variable Assist - 99-02 B GM# 26055105
- All - 02-03 B GM# 26073562
4 - Boot Kit - 99-03 GM# 26035404
Clamp
5 - Large - 99-02 GM# 7840235
6 - Small - 99-03 GM# 3786276
7 - Ring - 99-02 GM# 7831234
8 - Line Kit - 99-03 R GM# 26053451
9 Line Kit - 99-03 L GM# 26053450
10 - Adapter - 99-03 GM# 7833732
11 - Seal kit - 99-03 GM# 26032824
12 - Housing cover - 99-03 GM# 7846884
Pumps and Hoses - 2.2 L
1 P/S Pump - 02-03 GM# 26091879
2 Mount bolt - 02-03 GM# 24575780
3 Mount Stud - 02-03 GM# 11519819
4 P/S Reservoir - 02-03 GM# 26086235
5 Reservoir Cap - 02-03 GM# 26095240
6 Upper Return Tube
- w/o Variable Assist - 02-03 GM# 22679182
- w/ Variable Assist - 02-03 GM# 22679182
7 Pressure Hose - 02-03 GM# 22685424
8 Return Hose - 02-03 GM# 26065890
-- 2.4 L
1 P/S Pump
- w/o Variable Assist - 99-01 26047567
- w/ Variable Assist - 99-01 26072516
2 Seal - 99-01 26040230
3 Mount Bolt - 99-01 24575780
4 P/S Reservoir - 99-01 26038090
5 Retainer - 99-01 R 26028255
6 Retainer - 99-01 L 26028254
7 Reservoir Cap - 99-01 26095240
8 Upper Return Tube
- w/o Variable Assist - 99-01 26041998
- W/ Variable Assist - 99-01 26041997
9 Pressure Hose - 99-01 26072757
10 Return Hose
- 99 26068108
- 00-01 26065890
3.4 L PS Pump
1 P/S Pump
- w/o VAriable Assist - 99-03 26043370
- W/ Variable Assist - 99-03 26072519
2 Bolt - 99-03 24503695
3 Pulley - 99-03 10166335
4 P/S Reservoir - 99-03 26048008
5 Retainer - 99-03 R 26003553
6 Retainer - 99-03 L 26003552
7 Reservoir Cap - 99-03 26095323
8 Pressure Hose
- w/o Variable Assist - 99-02 26068979
- w/ Variable Assist - 99-02 26066518
- All - 03- 26068979
9 Return Hose - 99-03 26070058
10 Upper Return Hose - 99-03 26055389
Steering Column Assembly
1 - Column Assy
- w/o cruise, w/o Variable assist, w/o accessort contrl
- 99 26077614
- 00-03 26074892
- W/Cruise Contrl, w/o variable assist, w/o accessory contrl
- 99 26077617
- 00-03 26098132
- W/Accessory contrl
- 99 26077615
- 00-03 26074888
- W/Cruise contrl & Variable Assist, w/o accessory contrl
- 99 26077618
- 00-03 26098133
W/Accessory contrl
- 99 26077616
- 00-03 26098135
2 - Support Bracket - 99-03 22623704
Closed Thread
