Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-18-2007, 09:46 PM
griff305 griff305 is offline
92 camaro problems
car doesnt want to fire over. When solenoid is bridged it turns over motor. But no power in gear selector switch any ideas???
Old 01-18-2007, 11:25 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: 92 camaro problems
ignition switch,vats,and 100 other things could be wrong. By the battery there sould be this little solenoid, take a look at it and make sure it is hooked up right. And also chack all wires plus the one going to the starter. First off check fuses.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 01-19-2007, 08:50 AM
thanks ignition is good ill get on the rest today hopefully it is just a bad connection.
Old 01-19-2007, 10:33 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
On the solenoid, the smaller purple wire which is the S terminal, do you have 12 +/- with the key in 'run' ?
Old 01-19-2007, 10:03 PM
what is the VATS?
Old 01-20-2007, 08:34 PM
Morley Morley is offline
Originally Posted by griff305
what is the VATS?
Vehicle Anti Theft System. There is a resistor "chip" on your ignition key that is read through the ignition lock and to the VATS module. If the incorrect key is put in the ignition the starter will not engage. A broken module/wiring will also cause it to not engage the starter.
Old 01-20-2007, 09:30 PM
how do i test for it?
Old 01-22-2007, 10:36 AM
wrightz28's Avatar
Old 01-22-2007, 11:44 AM
Blue Bowtie's Avatar
Registered Offender
Re: VATS
92 camaro problems
Wow! That's a LOT of Camaro problems. I was guessing that you only had one.
For an idea of the operation of the VATS system, check this page:
VATS System Overview
Old 01-22-2007, 11:43 PM
how do i know if it is a vin e or f because i want to get the online manual
my FP23E is the vin
Old 01-23-2007, 10:14 AM
wrightz28's Avatar
my FP23E is the vin
The car's VIN # ???
IF you're trying to identify the engine VIN code it is the 8th digit on the tag in the lower left corner of the windsheild.
Otherwise:
E - 5.0 (305)TBI
F - 5.0 (305)TPI
8 - 5.7 (350)TPI
Old 01-23-2007, 12:59 PM
thanks the vin # i posted was the vehicle identification on the vin i appreciate it alot.it is TBI. The previous owner didnt even have the decoder module plugged in. He ran a switch from the grey wire and he cut the green loop in the module.What is the clear connector with a green and red led in it?
Old 01-24-2007, 11:23 AM
Registered Offender
Green and red LED? That doesn't sound like a factory item.
If the wires are cut, and the ECM doesn't get the 30 Hz sinking input, and the ECM hasn't been reprogrammed, you'll be trying to start it for a LONG time.
Old 01-24-2007, 12:26 PM
do u have to bring the ECM to dealer to be reprogrammed and about how much does it cost?
