Old 01-18-2007, 05:17 PM
F1 monster F1 monster is offline
F1 drawings
Fellow on pistonheads, by the name of Stephen Mullins, made this drawing:
Please link other people's F1-related art in this thread.
Peloton, if this grows into a nice bunch of drawings/artwork, maybe you could link to it in your thread on top?
Old 01-19-2007, 01:50 AM
hurstg01's Avatar
hurstg01 hurstg01 is offline
Re: F1 drawings
not a bad try, some of the proportions are out but if it was done freehand on a computer
Instagram/
Old 01-19-2007, 08:38 AM
Peloton25's Avatar
McLaren Fanatic
Re: F1 drawings
While not identical in every respect, I suspect that this image may have provided a template or just some inspiration for the artist. It was taken at the Nurburgring 4 hour race in 1995.
>8^)
ER
Old 01-19-2007, 08:55 AM
Re: F1 drawings
Interesting what he's done with the front air intakes, covering them up partially. Were they ever like that in real life? And where are the links to other drawings? Come on, you lot.
Old 01-19-2007, 09:28 AM
Peloton25's Avatar
McLaren Fanatic
Re: F1 drawings
The original design of the '95 GTR front ends had those smaller openings. Later on they redesigned the nose piece with larger vents similar to those we are used to seeing, but they offered small plates to block some of the air flow at races in colder climates.
Nick Mason's #10R seems to wear the plates permanently as don't think I've ever seen it photographed without them. Here's a decent closeup shot:
I'll post some drawings I have later.
>8^)
ER
Old 01-19-2007, 12:27 PM
Le Man's Avatar
Le Man Le Man is offline
Re: F1 drawings
F1 monster, do you require complete car drawings only?
Here are some nice ones!
The FINA GTR (08R?) looks like a graphic modified photo!!
Hear is a splendid drawing, done with needle and thread.
Please enjoy.
Old 01-19-2007, 12:28 PM
Re: F1 drawings
Le Man,
any drawing, at any stage of completion. I just want one thread to consolidate all links to drawings. Many thanks for your contribution--that needle point is simply amazing. Must be a computer-controlled machine?
Peloton, no, I am talking about the NACA ducts just inboard of the headlights. See the squares drawn in at the top of those, presumably to block off airflow? Has that ever been seen on a real F1? Wonder why they are drawn like that.
Old 01-19-2007, 12:40 PM
Le Man's Avatar
Re: F1 drawings
Originally Posted by F1 monster
Le Man,
I,ll see what I can do
The NACA ducts you see are the early 95 spec. The front brake and radiator cooling got an update at around mid season (LeMan) These NACA ducts were then deleated. Some 95 cars still have this set up, 07r being one of those.
As for the embroidery, This was emblazoned onto the rear of the Gulf Team jackets for top team personnel and sponsors only.
Old 01-19-2007, 02:25 PM
Re: F1 drawings
Le Man, what I meant was, if you look at the drawing, you see that he has drawn a square panel at the top of the NACA duct, as if it can be closed off partially. Seen that on any real F1?
Old 01-19-2007, 02:53 PM
Peloton25's Avatar
McLaren Fanatic
Re: F1 drawings
When they did some of the first shake down runs of #01R (Silver/Orange paint scheme) I saw those triangular vents covered over with tape in one photo. It was probably pretty cold at the time. Never seen any kind of cover in that location otherwise. They either had the vents or didn't.
>8^)
ER
Old 01-19-2007, 03:26 PM
Le Man's Avatar
Re: F1 drawings
Yes.
02R...............And without 01R
It is a small carbon infill panel, that was added to aid air flow.
Old 01-19-2007, 04:32 PM
Sccrplyr06's Avatar
Sccrplyr06 Sccrplyr06 is offline
Send a message via AIM to Sccrplyr06
Re: F1 drawings
So I posted this drawing on here when I completed it 3 years ago, but I felt like I might as well share again.
Old 01-19-2007, 07:13 PM
payso's Avatar
payso payso is offline
Re: F1 drawings
am i right to say? if you look real close at the image P25 posted, those small covers are actually on the Gulf car in the original image
Old 01-19-2007, 09:56 PM
Re: F1 drawings
Aha, mystery solved. Thanks guys, never had noticed those panels before.
