Old 01-18-2007, 04:08 PM
sport01 sport01 is offline
oil pressure
My oil pressure gauge has been running very low. Can anyone tell me what the normal operating range is? Thank you. 2000 blazer 4.3 v6
Old 01-18-2007, 06:02 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: oil pressure
Dash gauge is only a electrical gauge indicator.
Rule of thumb is a 1/4 gauge or more at idle and 3/4 gauge at 3000 RPM.
But better to put a manual test gauge on it and see what the actual pressure is.
Post back pressure with a manual test gauge.
MT
Old 01-18-2007, 08:58 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: oil pressure
if you want to use the dash guage as a reference, oil psi is usually 25-35 at idle and 40-50 under load. this is with the engine up to temp. if you want to know the true reading, use a mechanical guage like MT said.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 01-19-2007, 11:14 AM
Re: oil pressure
Thank you for the information. I don't have an oil pressure tester, but I am planning on getting one soon.
Old 01-19-2007, 11:42 AM
MT-2500's Avatar
AF - Advisor
Re: oil pressure
That is the only true test
Dash gauge is only a electrical Indicator and sending units can go bad.
Another note if you are not using a AC delco oil filter get one and see if it improves oil presure.
Let us know how it goes.
MT
