Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-18-2007, 01:16 PM
snarfman snarfman is offline
service engine code
I have the service engine light on Took it to autozone and they read the code and said it was code "P1406 EGR postion sensor performance"
Dealer said there is no postion sensor just the EGR valve and other stuff.
Any idea what this code means. Its on a 1996 sub 454 4x4 k2500
Thanks
Old 01-18-2007, 04:06 PM
2000CAYukon 2000CAYukon is offline
Re: service engine code
Thanks
OBD II Codes can be used by more than one auto maker. Autozone gave you the meaning for P1406 but unfortunately not for GM.
For GM is means:
DTC P1406 EGR Valve Pintle Position Circuit
The PCM controls the EGR and it detected that it is not responding. You could replace the EGR or have someone with a scan tool diagnose the EGR valve.
//2000CAYukon
Old 01-18-2007, 07:37 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Thanks
http://members.troublecodes.net/crunch/1406t.pdf
MT
Old 01-20-2007, 04:19 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Thanks
Dealer is wrong, position sensor is part of the valve.
The VCM constantly monitors the linear EGR valve pintle position sensor in order to ensure that the valve is responding properly to the commands from the VCM.
The following conditions will set the DTC:
EGR pintle position signal indicates a voltage out of the normal range of the pintle position sensor, or a signal that is 10% greater or less than the VCM commanded position
Ignition voltage greater than 9 volts
Typically the sensor or valve schew, Test the sensor circuits first.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
