Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-18-2007, 01:14 PM
christinao8806 christinao8806 is offline
Wink reverse lights and horn help PLEASE !!!
I have a 1997 Eclipse and my reverse lights have not been working. I've replaced the bulbs and tested the fuses. Friends of mine have said it could be the switch which apparently is by the shifter, but I have no idea where. If someone could let me know where to find and how to check that, or what else could be the problem I'd appreciate it.
Second question my horn has not worked since I had my engine swapped and I have no idea where to start to fix the problem if anyone has some suggestions as to why it's not working and how to fix it that would be great.
Old 01-18-2007, 01:21 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: reverse lights and horn help PLEASE !!!
ok, first, is the car turbo, or non-turbo?!? they have two different transmissions/engines...
Edit: Second, is the car Auto or Manual?!?
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 01-18-2007, 03:15 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Yeah, what trim is the car? That definitely makes a difference. And auto or manual? If it's an RS/GS, the horn is behind the front bumper on the passenger side corner, it was most likely unplugged or the wire was broke/cut when you had the motor replaced.
95 Talon TSI AWD
97 Eclipse GST
Old 01-18-2007, 03:21 PM
Mikelb's Avatar
I don't have reverse lights either, but I don't have to have them in my state(NC)
