Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-18-2007, 12:16 PM
4g63rice 4g63rice is offline
SAFC installtion
How is this done, do i combine the safc wires with the exsisting wire or do i cut the exisiting wire and replace it with the safc ones?
Sort of confusing but i only have 5 min.'s
Old 01-18-2007, 12:22 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: SAFC installtion
Well, considering I just found this, your 5 minutes are up... Whats the big rush? This is something you don't wanna rush and screw up. Wiring up the AFC is very important. If you do it wrong you could cause some serious problems to your ECU settings...
You do not cut and replace any original wires. You only tap the AFC's harness into them...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-18-2007, 01:29 PM
Thanks a lot, I appreciate it
Old 01-18-2007, 02:49 PM
L-Spec's Avatar
L-Spec L-Spec is offline
Send a message via MSN to L-Spec
Yeah... what Brian said. The SAFC is not a stand alone. Doesn't it come with instructions anyway That probably would have told you in less than five minutes!
1992 Ẽfini RX-7 FD3S
Old 01-18-2007, 02:57 PM
steviek's Avatar
steviek steviek is offline
You do cut one wire. You cut air flow sensor and attach one side to one wire and the other side to another wire.. Thats where the afc converts the airflow enabling you to adjust for air fuel. vfaq has a wiring diagram
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 01-19-2007, 01:18 AM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
Check plymouthlaser.com too!
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 01-19-2007, 02:55 PM
i have 2 more questions:
1) Shouldn't the safc come on with the key turned all the way to the right without cranking the engine with all the dash lights on?
2) If you have a safc that does not work and is connected to the car, will it make the car not start?
Old 01-19-2007, 03:25 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
1) Yes
2) Could possible. Depends on how bad it's messed up and if the wiring is done right.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-19-2007, 06:20 PM
We'll the car was just running fine with the safc working and than all the sudden it wont start anymore. When this happend the safc won't turn on anymore. So can it be the safc causing the car to not start? Any thoughts?
Old 01-19-2007, 06:52 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
That would be an electrical problem. Which circuit did you tap the SAFC into? That's where I'd start looking for blown fuses.
95 Talon TSI AWD
97 Eclipse GST
Old 01-20-2007, 09:24 AM
We'll the car that has this problem i'm planning to get for $1,500. This is the only reason he wants to sell it.
The car i'm getting is a 91 mr2 turbo with mods already:
1-trd widebody(car is color blue)
2-20g turbo
3-tenzo R rims(i think rs5)
4-safc
5- gauges and all them little things.
Do any of you guys think it is worth buying when the car doesn't turnover?
Old 01-20-2007, 11:15 AM
Well, I'd definetly consider it to be a problem... I would never buy a car that doesn't run unless I knew specifically what was wrong with it and if it was a simple fix...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-20-2007, 11:38 AM
If i buy it and fix it, i should be able to sell it for at least $5,000 making a whole lot of profit.
Old 01-20-2007, 02:16 PM
And if you can't fix it, then what? Then you wasted $1500. It's really up to you if it's worth taking the loss, or if it costs more to fix than what you'll get back out of it.
95 Talon TSI AWD
97 Eclipse GST
Old 01-21-2007, 11:28 AM
I'm thinking if i can't find out what's wrong with it, i'm going to drop a new motor in it which will cost about 2g's and maybe $500 for wear and tear parts. Add it up and get a total of $4,000 for everything. Then i can sell it for about 5g's to 6g's and make $1,000-$2,000 profit.
It should work if i drop in a new motor that comes with all the wiring's and ecu.
