Old 01-17-2007, 09:53 PM
96transamguy88's Avatar
96transamguy88 96transamguy88 is offline
quick question
hows come on the head of an lt1, where the manifolds bolt up, the outside has 2 threaded holes..... on is used for the very outside manifold bolt, but to the inside of that there is an unused threaded hole. whats the deal with that????
thanks kyle
1996 Trans am-
lt1 6spd
pacesetter lt's
ory-pipe
160* thermostat
slp fan control switch
4:10grs
cobra wheels
slp intake
hurst short throw
magnaflow catback
Daily Driver-86 4wd danger ranger
Old 01-18-2007, 02:35 AM
Morley Morley is offline
Re: quick question
The LT engine was used in different vehicles and they all had different types of manifolds, some used the inner bolt hole and others used the outer one.
Old 01-18-2007, 05:31 PM
Re: quick question
ok.... thats kinda what i thought..... cuz my pacesetter lt's use the two inner bolts... but thanks for the help. kyle
1996 Trans am-
lt1 6spd
pacesetter lt's
ory-pipe
160* thermostat
4:10grs
cobra wheels
slp intake
hurst short throw
magnaflow catback
Old 01-18-2007, 07:48 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: quick question
I believe but am not positive when I got my corvette block (which had its manifolds still on). It used the outside bolts.
Edit- X that. I believe those holes are used for mounting brackets for the accessorys on some models.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 01-19-2007, 10:11 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: quick question
Not sure if were talking about the same holes here, but the cylinder heads have holes drilled at each end and were used to remove/install the engine.
Old 01-19-2007, 09:50 PM
Re: quick question
no, these are the what the stock manifolds are bolted to the heads.... my pacesetters are set up where they use the inner of the bolt holes.
1996 Trans am-
lt1 6spd
pacesetter lt's
ory-pipe
160* thermostat
4:10grs
cobra wheels
slp intake
hurst short throw
magnaflow catback
