Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 01-17-2007, 07:56 PM
jacksfive jacksfive is offline
front wheel bearing change
Can anyone walk me through replcing a front wheel bearing drivers side on a 2000 Accent? What size socket do I need also to get hub off? Thanks
Old 04-26-2007, 06:49 PM
nickoolsayz nickoolsayz is offline
Re: front wheel bearing change
im working on teh same thing. my accent 1996 hatchback. took off the tire, removed teh brake caliper(2 bolts maybe 5/8-11/16. cant remeber but noticably larger than others) then took of large center bolt of the cv axel. going to be hard but i had to pull teh brake rotor off. i found 2 sets of bearings, and 2 wheel seals. im guessing they needs replacing to fix my problem(tire was a lil loose, not lugnuts, when i jacked my car up and jiggled it)
hopefully someone else can help us.
