Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 01-17-2007, 07:05 PM
bigdaddygnar bigdaddygnar is offline
Send a message via AIM to bigdaddygnar
just making sure...?
i believe i read somewhere that suspension mods for any sentras 2000+ with fit on all models. example: springs for a spec v would fit on my GXE. right?
Old 01-17-2007, 10:46 PM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
Re: just making sure...?
ooohh...uhh, I'm not completely sure, but I'd have to give that theory a "Nay".
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 01-18-2007, 04:24 PM
slideways...'s Avatar
slideways... slideways... is offline
springs and shocks id bet would work, im pretty sure that all model sentras have macpherson struts in front and minivan rear axle... some things wont work though. if you have a little cash laying around, buy a set, and then buy a set of stock parts, compare the two sets, then return them.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 01-22-2007, 05:31 AM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
2.5 and 1.8 suspensions are not interchangeable, totally different control arms and everything
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
Old 01-22-2007, 02:04 PM
consider me enlightened
Old 01-22-2007, 02:09 PM
bummer. thanks tho
Old 01-22-2007, 03:55 PM
i bent my control arm on my 2.5 and i was hoping a 1.8 would replace it, but the under frame is completely different, more likely that an altimas suspension would interchange
Old 01-22-2007, 04:50 PM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
but, you can interchange the spec-v suspention from aftermarket onto any b15 correct? or did i read something wrong. like if you changed the shocks and springs for a coilover set or soemthing.
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Old 01-23-2007, 08:58 PM
if your struts are made to mount to a 2.5 control arm they will not bolt onto the 1.8 arm, but the springs ive heard are interchangeable to stiffen the ride of the 1.8
