Old 09-25-2002, 08:08 PM
Gusto222 Gusto222 is offline
Send a message via AIM to Gusto222 Send a message via Yahoo to Gusto222
Removing Alternator -- HOW TO?!
Hey i need to replace my OEM alt w/ my new high output one.. How do i go about removing it.. i heard u have to R&I a bunch of stuff(incl. axels)... but there yusta be this guy on purehonda.com - who told me he did it to his civic w/ OUT any R&I(remove & install) --
If any1 knows how to do it.. or knows a link wehre they show how to do it-- w/ tha elast amount work-- hit me back asap!
I drive a 1996 Civic HB(cx) - No a/c
~Gusto~
yeah i know i cant spell....
'96 civHB:shaved:19" rims:3000w stereo -- SOLD
'97 Tacoma:2wd:lifted -- SOLD
'00 Dakota.QC:lifted:33"tires ---SOLD
'06 Mazda3.GT:Eibach:mazdaspeed I/E
Old 09-25-2002, 11:15 PM
Tominos Tominos is offline
just take off connector at alternator, remove alternator bolts, and belt and thats it. its gonna be kinda difficult since the alternator is in the rear of the engine. good luck
Old 09-26-2002, 07:08 PM
delsolsi delsolsi is offline
Re: Removing Alternator -- HOW TO?!
I encountered the same thing when I tried to change the altenator in a delsol I used to have. After trying unsucsessfully to remove the altenator I got out my manual and it said to remove the axle. So I said screw this and took it to an altenator shop and they were able to get it out with out removing the axles. I asked how they did it and they said if you jack it up just right you can get it out. This is easy for them because they have a pit under the car they can work from so they don't have to jack the car high enough to fit under.
Old 09-27-2002, 01:51 PM
thanks alot man-- ill try n do it when i get my car back in 2 weeks.. i need to have tha system in... all these damn parts lying around is crazy.....over $4k worth of stereo parts.....
~Gusto~
Old 06-26-2005, 12:01 AM
thirdstring thirdstring is offline
Jack up driver side
I just finished replacing an alternator on a 1996 Civic. After putting the car on ramps, I took out the top bolt, the 2 wire connections on the back of the alternator, plus the wire hold-down bolt on the back of the alternator, then the bottom bolt (actually, it wasn't even in there!), then the bracket that the bottom bolt goes in. There wasn't clearance to get the alternator out, so after finding this thread I jacked up the driver side until the front driver's wheel was fully extended (the axle stopped going down even if I went higher). I put in a jack stand for safety, and after trying a few different directions, was able to pull the alternator out of the left side of the compartment from the bottom, just above the axle. Oh yeah, the black plastic shield/air dam on the bottom front of the car was removed, but I don't know if that was necessary.
How To R&R 1998 Grand Caravan Power Steering Pump CarBob Caravan | Voyager 0 04-04-2010 10:59 AM
How to remove headlight LENS on 1999 Grand Marquis LieutenantCracker Grand Marquis 0 01-29-2010 10:53 PM
How to remove alternator? Omar_I30 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 06-19-2005 11:35 AM
2000 teg removed catalytic, how to fix check engine? herbal77 Integra 0 04-06-2004 11:40 PM
Removing Alternator -- HOW TO?! Gusto222 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 09-25-2002 08:10 PM
