Old 01-17-2007, 05:46 PM
no_import2007 no_import2007 is offline
Gtp Motor In A 2005 Grand Am
Would A Gtp Motor Fit In A Grand Am?????
Old 01-17-2007, 09:17 PM
MVGTP86 MVGTP86 is offline
Re: Gtp Motor In A 2005 Grand Am
yes it would...would be lots of work though making the swap..wiring harnesses, pcm tunning, transmission work, ect...
2003 GTP - Brand New L67 crate engine, K&N FWI, Ported TB, 3.4 s/c pulley, Walbro 340 fuel pump, 180* T-stat, 1.9's, PEM'S, ZZP 3" Down Pipe, ZZP 1.0 PCM, gutted cat, u/bend - resonator delete, magnaflow mufflers and tips.
Old 01-18-2007, 12:37 AM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Like MVGTP86 said you could but it would be an incredible amount of work plus it wouldn't bolt up in the engine bay. You would save money and an incredible amount of time and headache to just buy a GTP.
Old 01-18-2007, 07:07 AM
GTP Dad GTP Dad is offline
Pontiac Guy
I agree! Save your money and trade the Grand Am on a GTP. The amount of money and work that it would take would cost you more than buying a GTP in the first place.
Old 01-18-2007, 07:41 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Actually A GTP engine wont fit very well in a GA
If you have ever seen a GTP engine bay, its larger then the 05 GA's.
So even it you got it to "fit" , it would cost around $3-5k,
Plus several hundred hours of work.
Not even worth the headaches or the money!
I agree with GTP Dad, trade the GA in on a GTP
1999 Grand Am SS 3.4 OHV
Old 01-22-2007, 09:18 PM
several hundred hours???????? not to start nothing but its been done before....i seen GA wit gtp motors....
Old 01-22-2007, 10:13 PM
I didnt say it hasnt been done, that is putting a 3.8 in a GA.
The SC 3.8 is bigger and I havent seen nor heard of any GTP motors in GA's.
Mizly motor sports is working on a conversion kit for the 3.8 and or trans swap.
That being said, 200-300hrs is not unreasonalbe at all.
Considering removal of motor, replacing the steering knuckles,
because the 4t60-4t65 tranys use larger CV joints/shafts and wheel hub sensors.
Then some other suspension parts need modified/swapped.
Then you have to swap wiring harnesses/pcm.
You ever do a wire harness swap?
I have, and it bites
And if you never have done any FWD engine/trans removals,
you could spend even more time doing this "little" swap
Old 01-23-2007, 04:40 PM
VR43000GT's Avatar
There is going to be a lot of custom work and fittings you would have to do yourself. And I think 200-300 hours would be if you had a game plan going into the build and really knew what you are doing. God knows how long it simpily took for me to swap a transaxle 6G72 and put in that same exact motor. Even that was a PITA for me.
Old 01-23-2007, 06:59 PM
I know of serveral people who have put L67's (s/c 3.8's) in cavaliers with not to much problem. It would be an easy fit in a grand am, and yes if seen L67's in grand am's there is one i just saw on cardomain. And the s/c 3.8 isnt bigger than the N/A 3.8L, its the same cubic inches and liters it just has an eatons blower/supercharger on top that makes it a couple inches taller but thats all, it uses a different intake manifold than the N/A 3.8l because of the Supercharger.
Old 01-24-2007, 10:52 AM
well lets see some pics of that cavilier!
And the grand ams with SC-3.8 !!!!!!!!!!!!
I didnt say the motor displacement was bigger
I just said it was bigger, sixe wise
ps not some photochoped pos either ~
Old 01-24-2007, 01:53 PM
Here is a pic of a 98 cavi w/ an L67 swap.....
and here is the cardomain website from the guy that did the swap
http://www.cardomain.com/ride/526752
Here is a pic of an L67 in a Grand Am
and another
and here is the site that tells you everything you need to know about doing an L67 swap in a GA. http://www.engineered.net/
Do you need anymore pics b/c i have more of L67's in every body-style of grand am.
Old 01-24-2007, 04:08 PM
GTPCatz GTPCatz is offline
Banned
Heres another good site for swapping engines and you will find a few that have done it here
http://motorswap.org/
Old 01-24-2007, 06:45 PM
I never said it could not or has not been done MVGTP86.
IMO its just a waste of time and money.
And the Cavalier would be easier because I'm preety sure they have the same motor mount locations. I'd sure the heck hate to change the plugs in that, might have to drop the motor
btw I already know what it takes to do this swap.
Which I could realy care less about the 3.8, All I want is the 4t65 trans in my GA on the 3.4
Old 01-24-2007, 09:50 PM
AROUND HOW MUCH DO U THINK DA COST CAN BE TO PUT IT INTO DA gA...????????
Old 01-24-2007, 11:19 PM
Please lay off the caps, we are not blind!
And on the cost, more then you would like.
You'd be better off just buying a GTP.
But if you have a gtp motor and a ga, well thiers half the cost. The rest would be time and odds and ends parts.
Good Luck!
