Old 01-17-2007, 05:42 PM
zapata_mx zapata_mx is offline
I need the location off VSS and TRS WIndstar 95
I want to know the location of the VSS and TRS in windstar 95 and If Its easy to change the sensor, Can I do it by my self? thanks
Old 01-18-2007, 08:13 AM
busboy4 busboy4 is offline
Re: I need the location off VSS and TRS WIndstar 95
Hi
I am assuming the 3.8L here o.k.? The VSS is located on the rear right of the transmission housing. It is most easily seen from beneath the van, and is hard to see even there. look for a cylindrical sensor mounted horizontally with a wire bundle attached, behind an aluminum heat shield. Should look something like:
http://info.rockauto.com/SMP/SMPDetail3.html?SC46.html
The TRS is located on top of the transmission directly in front of the driver and under/slightly rear of the air intake assembly. Here is a photo from Wiswind's site (you will want to bookmark his page)
http://rides.webshots.com/photo/1345...11220610vMUSlZ
As to easy to change: the TRS should not be too difficult. The VSS is hard to get at - I have not changed mine, but it is buried up there.
Best of luck
