Old 01-17-2007, 01:23 PM
LotuS87 LotuS87 is offline
Turn signals dont work
Dont blink inside car or outside.
No clicking blinker noise like normal
the switch works and stays on and goes back to regular position on turns.
Someone told me it might be the turn signal flasher?
Where is my turn signal flasher and can I change the part myself? and how much do they run...
1996 park ave 3.8
Old 01-17-2007, 05:29 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: Turn signals dont work
Have you checked your fuses? Also, have you tried your emergency flasher? If your fuses check out ok, the turn signal flasher should be under the dash, driver side near the steering column. It'll be held up with a clip, but can easily be removed and disconnected by hand. AutoZone has them for less than 10 bucks.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 01-18-2007, 12:09 AM
Fused checked and are fine, sorry forgot to say that earlier. I will look for the flasher thingee in the morning.
Old 01-19-2007, 05:54 PM
HondaManDan's Avatar
HondaManDan HondaManDan is offline
Send a message via AIM to HondaManDan
Make sure your battery terminals are tight!!! Mine came loose and the same exact thing happened. Tightened them up and boom, fixed.
95' Buick Park Ave... hell yeah.
Old 01-23-2007, 09:43 PM
it was the turn signal flasher. swaped the turn signal flasher with the hazards flasher (they looked similar enough :P ) and the turn signals started working! so ya now i have no flashers
Old 01-24-2007, 08:26 AM
Loekee75's Avatar
".... so ya now i have no flashers"
about 10 bucks will buy you a new one at most auto stores. Or go even cheaper at the boneyard.
