Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-17-2007, 10:41 AM
darkies darkies is offline
Jeep shaking
96 Jeep Grand Cherokee Limited v8 4x4.
When I'm driving down the road around 50 mph, the steering wheel starts to shake back and forth. The car also vibrates with it. My passenger seat is now making a noise because its shaking so bad. Also I have to hold my steering wheel to the right to make the jeep go strait. It isnt getting any better over time, thats for certain, any ideas?
Old 01-19-2007, 01:35 PM
SherylUpchurch SherylUpchurch is offline
Re: Jeep shaking
Sounds like it is time for a front end alignment. If you don't do it soon, your tires will wear.
Old 01-19-2007, 01:43 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Jeep shaking
Yup, alignment. Today.
While you're at it, have your tires balanced if they've got more than 15-20K miles on them.
You don't want this to get any worse, that's for sure. Do a search under "death wobble" in the Wrangler section and you'll see why.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 01-19-2007, 06:02 PM
jeeper186's Avatar
jeeper186 jeeper186 is offline
Re: Jeep shaking
Thats for sure. If you have done any lift or if any of your bushings are worn, you could be getting death wobble. Have them checked out to.
1947 Willys on Chevy frame, 350ci, 488 gears with detroits front and rear.
1997 JGC
1998 JGC
1995 JGC 7" lift 231 T-Case 33" tires.
Yes, I love JEEPS!
Old 04-04-2009, 11:31 AM
GRABAWRENCH GRABAWRENCH is offline
Re: Jeep shaking
Hay while u are at it make sure u dont have a brake caliper sticking.
Old 04-28-2009, 11:40 AM
JeepForever JeepForever is offline
Re: Jeep shaking
Death Wobble can often be resolved with an alignment, steering stabilizer, and/or track bar. In my '94 GC I replaced my steering stabilizer and it solved most of the problems. When wobble happened again I replaced the track bar (at the same time had wheels aligned) and haven't had trouble since then.
Old 04-28-2009, 10:40 PM
racer77 racer77 is offline
Re: Jeep shaking
check the tread on the front tires. if one tire is newer then it will pull to the other side. that just happend on the cherokee i just got.
there was a wobble and pulled to the left.i senn there was a new tire. had the front tires put on the back, and had the tires ballanced and now it rides real nice.
