Old 01-17-2007, 08:15 AM
KMSwigart KMSwigart is offline
93' Abs Not Working!
I have a 93' LeSabre and the ABS does not work. The ABS light is not on and no codes. It just does not work. Hit the brakes and they lock! Checked fuses and they are good.Car is giving me nothing, any ideas??
Old 01-18-2007, 02:42 PM
maxwedge maxwedge is offline
A990 racer
Re: 93' Abs Not Working!
Start with the relay and both abs fuses, see if they are in place or blown.
Old 01-18-2007, 03:32 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
In case you need locations of ABS fuse & relays
Fuse panel under dash, drivers side:
Under hood relay & fuse center:
Old 01-19-2007, 05:52 AM
Checked those and still nothing. If the ABS computer is dead will the light come on? Can I take it out and have it tested? Where? Also I have been looking at parts online and they have three different master cylinders for the car, which one should it have? The 8'' master cylinder is on it now.
Old 01-19-2007, 12:11 PM
A990 racer
It is under the l/s of the dash remove the lower cover to access looks like a small pcm. BTW nices pics, HotZ28
