Old 01-17-2007, 03:25 AM
Gamerxz's Avatar
Gamerxz Gamerxz is offline
Enzo Help needed ( Anyone who can create rims please drop in)
Hi im looking for this set of rims for my enzo . From my knowledge i have never seen this rims in plastic , So im guessing i need someone to make one out of metal or smt. So if anyone can do one set please leave me a quote of your price. Also if anyone has seen it in molded plastic and know where to get one set please do point me in the right direction! Much thanks in advance
Old 01-17-2007, 04:55 AM
nniemi's Avatar
nniemi nniemi is offline
Re: Enzo Help needed ( Anyone who can create rims please drop in)
Sakatsu has made wheels that are quite close to those you want:
http://www.mediamixhobby.com.sg/cata...oducts_id=2922
-Niko
Old 01-17-2007, 01:37 PM
Enzoenvy1's Avatar
After looking over Hiroboy's FXX pics yesterday, I saw these too!!! THey are beautiful on the ENZO, I will pay for some also.......opcorn:
Those Sakatsu rims would almost be impossible to modify................
Old 01-17-2007, 02:51 PM
hirofkd's Avatar
hirofkd hirofkd is offline
I like that wheel on that silver Enzo, too. It look like a BBS, but with very sparse design: 7 double spokes. I've never seen anything like that in plastic, so I guess you (or someone else) have to make one yourself.
Hiroaki Fukuda
Old 01-17-2007, 03:35 PM
robrex's Avatar
robrex robrex is offline
Here are a few I found. I'm not sure about the size of these Mini Z wheels? I think the cars are 1/28 scale???
http://www.hlj.com/product/SQUSKM-007HS
http://www.hlj.com/product/SQUSKM-007GS
Rob
Old 01-17-2007, 03:39 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Mini-Zs are, I think, 1:18. They are the Kyosho cars that are essentially the same as a 1:10 RC car, but smaller. Not like the Radioshack cars, which are 1:28.
Old 01-17-2007, 04:43 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Wow, they are pretty aren't they? I've actually been looking at that pic all day, and thinking. I simply do not know if I could machine that- but I just might be tempted to try. They would not be quick, and they would not be cheap. And I doubt I'll get much chance to try before mid March or so. If I can do it, each wheel would be a two part affair, with a resin face and a turned aluminum rim, possibly with a separate aluminum or resin center pin like the 'rivet' in Tamiya's F40 wheels.
I may think about it for a bit....
PHOTOBUCKET SUCKS
Old 01-17-2007, 05:31 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
I made something similar for my current Super 7 project, (I just had to make it a 7 spoke design...) As MPWR said, not quick, and not cheap. I machined the center for mine from aluminum. Very time consuming and many chances to screw it up and waste a lot of effort... I got lucky, made it through the first time out, (long time) out... - Mark
Old 01-17-2007, 08:51 PM
Enzoenvy1's Avatar
Put some thought into it, I know you of all people can do it. And I know I would buy a few sets.
Old 01-17-2007, 11:01 PM
klutz_100's Avatar
Me too
It would make an interesting WIP in it's own right!
Old 01-18-2007, 03:38 AM
Gamerxz's Avatar
I have been working on this all day and this is what i got. Progress will be on my FXX thread.
I think if i find someone whose good at casting ill pass him my set as master to cast
thats where im now...
Old 01-18-2007, 08:43 AM
MPWR's Avatar
Yeah, and having seen your pics on how you did it is what's got me thinking about this one. Wow, how many different 7 sided parts did you make on your rotaty table? You must have had X(360/7) memorized and been reciting them with ease in your sleep- or is your rotary table CNC?
Why 7, damnit? I'm happy with 1, 2, 3, 4, 5, 6, 8, 9, 10, or 12- but 7 or 11 are truely obnoxious.
But really right now it's the triangular cutouts between the double spokes that are elluding me. If I had a full XY base for my mill, I think a .010" slitting saw might do it nicely. Still I'd rather do it vertically, maybe with a 1/32 end mill- but then they have their obvious limitations, don't they? (I broketwo in one day a week ago. ) Either way, it's alot of trig....
PHOTOBUCKET SUCKS
Old 01-18-2007, 10:00 AM
Gamerxz's Avatar
Hi .... MPWR do u know anyone whose trustworthy and good at casting?
This is where im now on the rims.. currently working on cleaning it up
Old 01-18-2007, 10:15 AM
No CNC for me, all old school. Don't even have digital readouts. Haven't quite memorized all seven figures around the table, but I can tell if it's not the right number at a glance, (usually before I cut!).
The triangular "corners" as opposed to the "radius's" on my wheels would add another step. Without a slitting saw, I guess probably some hand work to remove the radius with a file would be the way to go.
Oh yes, I have gone through my share of those little end mills. I always buy two or more at a time, unfortunately that's about the entire stock my supplier has on hand any given day. Once I broke my last one little more than 3/4 of the way through a project. Had to re-make three finished parts and start number four fresh too so all four would match, and on top of that I had to reset all my measurements to cut with a larger tool, (the tool supply store was closed on that weekend). It was the wheel knock-offs for a previous Super 7...
Your wheel is really coming along Gamerxz! - Mark
Old 01-18-2007, 10:59 AM
drunken monkey's Avatar
Razor Sharp Twit
how i would do it in a old school multi-part way
i) work on a master of plain wheel face - just the disk with the correct curves and whatnot on the face.
ii) make a master of the larger "hole" - replicate 7 of them
iii) make a master of the smaller (triangular) hole - replicate 7 of them
use the master face die to create a neg of the whole wheel.
in the neg, accurately locate and place the positives of the wheel voids.
cast.
y'see, triangular voids are easy(ish).
just you try and make a wheel with assymetric eliptical/oval voids like this one...
AF's Guidelines
Read them.
