Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-16-2007, 09:23 PM
crazy8 crazy8 is offline
1995 Bonneville W/ABS Master cylinder leak
I need to replace a leaking master cylinder on my Bonneville which has ABS. Can I get away with doing it in my garage or do I have to take it in since it has ABS? I currently am a heavy diesel technician and know my way around vehicles with air brakes but I'm not sure what I need to have to bleed the ABS system? Should I do it myself or take it in? Thanks
Old 01-16-2007, 09:27 PM
LMP's Avatar
LMP LMP is offline
Re: 1995 Bonneville W/ABS Master cylinder leak
Just changed the same on Z-34 last summer...no problem. Clearing all the stuff around to get it off is the annoying part. R&R is straight forward. Bleed using 2 bleeders on ABS unit..easy, no problem.
EDIT: ..just found...'95 Bonn. different from Z_34 I serviced....not sure of bleed setup
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 01-16-2007, 09:30 PM
I can't see any bleeders on the ABS unit located under the air cleaner. Where are they located? Do they look like regular bleeders?
