Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-16-2007, 07:15 PM
nehpets nehpets is offline
96 LE camry engine wont turn..possible lock up
The car will power up but wont start. i dont even hear a clicking sound. it has 178,000 miles and i would like to fix the problem, but dont even no where to begin to look. I dont wanna pay to get it towed to a shop,unless neccessary. Can someone help me please
Old 01-16-2007, 09:57 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 96 LE camry engine wont turn..possible lock up
Make sure your battery connections are tight and not corroded. If the battery has a charge indicator on the case make sure it indicates a full charge. If there are removable caps check the water level and top off if needed. Try jump starting the car with another car using jumper cables. If it starts let it run at least 20 minutes to charge the battery. Just because your instrument lights etc are coming on doesn't mean the battery is suppling all the power it is supposed to.
If you continue to have problems in the next few days, take the battery to a shop or parts store and have them charge it and perform a load test. If the battery is 4 years old or more just buy a new battery.
Try wiggling the gear shift lever and jiggling the ignition switch.
These are the first steps. If a jump start doesn't work, the battery charges and tests ok, or a new battery doesn't fix it, come on back. Do you have a multimeter or know someone who has one and can use it?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
