Re: what wheels fit a95 corrola
I wish I had a good list for you, but in general, the Chevrolet/Geo Prizm is a re-badged Toyota Corolla -- they have different factory steel wheel styles and even some aluminum sets that will fit.
Many aftermarket wheels have a universal 4-log pattern that fits a wide range of compacts -- in this case though, the wheel back-spacing (the distance from the mount surface to the inside "back" edge) is the most critical dimension and the factory wheel comes about as close as you can to the strut tower tube without rubbing, so any wheel you get should have the same or less back spacing.
14" diameter is the smallest rim size you should consider or the wheel may not clear the disc brake calipers.
195/60/14 is about the widest tire you would use on the stock steel wheel, anything wider (ie. 205/50/14) may make contact with the strut tube in the rear.
