starts then dies p0300 and p0440- achevia
im getting p0300 and p0440 on a 97 olds achevia the car starts real hard and then shakes then stalls where can i look first for this.
thanks again gmmerlin |
Re: starts then dies p0300 and p0440
I'd start with the p0440, which this is the hardest to find and you can only test so many things with Out the proper tools and manuals to diagnose this.
As you should know if you read GM Merlins Evap Emissions thread. Sounds like its not getting fuel, have you checked the fuel pressure? The p0300 is a random/multiple misfire. This could be caused by your igintion system, or from the fuel injection system. By igintion system I mean, plugs & wires, Coils, ignition module and its wiring. If its the injection syst, they could be clogged/dirty or have a damaged wire. I'd start by replacing the fuel fitler is its not be changed recently. Then check for spark. Then inspect all the hoses and wiring underneath the car by the fuel tank. The fill neck, all the smaller hoses can become loose over time and leak air. Should also be the Evap purge soleniod under thier, sometimes they go bad. Then you have the Evap canister under the hood and its lines that could be leaking. But this still doesnt even scratch the surface as to "what else" it could be. Sometimes this is easy to find, and other times you'll need a shop with the proper Tools. Keep me posted and Good Hunting.
1999 Grand Am SS 3.4 OHV
erase both codes see which one comes back first than check that circuit most likeley the p0440 will be first but if not than youll be chasing a ghost if it didnt
Please check the date of the last post in the thread and avoid posting in it if it is more than 3 months ago. Any questions please refer to the Community Guidelines.
Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
