Old 01-16-2007, 05:24 PM
Ogre1 Ogre1 is offline
Coolant leak
Tis the season for coolant problems...I have an active drip coming down off the back pass. side of the motor. 99 3.1L. I haven't gotten under it yet, the shops' full, but am kind of suspecting that it could be a freeze plug. Any ideas?
Old 01-17-2007, 05:12 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Coolant leak
Possible but it could be a hose or even the intake or head gasket. If it is back far enough and coming from the drain in the heater box it could be the heater core leaking. Wait until you can inspect it before jumping to any conclusions.
Old 01-17-2007, 05:47 PM
Re: Coolant leak
Well, I got the pos ford I'm overhauling out of the way and looked at my GP this afternoon. Near as I can tell, it is coming right from the bottom of the V so I am assuming a head gasket leak. Before I tear into the top of the motor I was thinking about trying something called water glass/liquid glass I heard about. Have you heard of that, and is it a possible fix?
Old 01-17-2007, 06:54 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Coolant leak
Water Glass is a no no.
Nasty stuff to fool with.
Will not mix with anti freeze anyway.
MT
Old 01-17-2007, 08:55 PM
nans_grandprix's Avatar
nans_grandprix nans_grandprix is offline
Re: Coolant leak
Here see the following thread http://www.automotiveforums.com/vbul...d.php?t=656443
Old 01-18-2007, 07:00 AM
Pontiac Guy
Re: Coolant leak
Before tearing the car down, do a pressure test on the cooling system so you are absolutely certain that it is a head gasket. It is a lot of work to change out a head gasket so you will want to be absolutely certain where this leak actually is. I agree that the water glass is not a product you want to use as there is no substitute for a proper repair.
Old 01-18-2007, 10:27 AM
Re: Coolant leak
Exactly, a lot of work to tear down to the head gasket. This car just crossed 200k so I am of the opinion that if I am going to get that far into it then I may as well pull and rebuild the motor. However, this is a dumpy 3.1L and I am looking for an upgrade so I don't know if I feel like doing this to a car that will be going to the rally or sold. Anyways, thanks for the feedback.
