Old 01-16-2007, 02:59 PM
djxchris djxchris is offline
Can't reverse, only drive in 2nd gear
Hi all. This is my first time posting here, hope someone can help. I have an automatic 1990 Infinity M30. The car will only drive forward in D and 2 so it's only driving in 2nd gear. Can't go in reverse. There is no difference between P R N or 1, can't feel a shift or anything, it's like the car is in park in all of them. In N I can only push the car forward, but not in reverse. In R I can hear a slight rattling noise. The transmission fluid seems fine and doesn't smell burnt. Would this problem need a new transmission? rebuild? or could it be somthing else? Any help would be appreciated.
Old 01-16-2007, 04:46 PM
gouldie1903 gouldie1903 is offline
Re: Can't reverse, only drive in 2nd gear
is the check engine/transmission light on?
and is it an electronicly control transmission?
i had a similar situation where it would only drive in 3rd but reverse worked. it was the computer's safe mode because i blew the fuse to the tranny controler.
if it isnt a computer controled tranny take off the fluid pan pan and see if there are any debris on the bottom.
hopefully it isnt something major
good luck,
chris
67 chevy c 10 needs paint
01 mustang gt needs hp
Old 01-16-2007, 07:03 PM
Thanks for the quick reply. I believe it is electronically controlled. I'll check the fuses and see if any are out.
